yapyap
Clipsal Zencelo
  blackcar said:
hi mine also having the same problem for the 2 Gang 2 way switches, both LED didnt light up at all. Did u resolve yrs?
Sorry i miss this reply. em... do u mean the ondicator or the heater LED switch?
Mine works...
If you switch on at point A, and go to point B to switch off <- point B onicator will be 'on' and point A ondicator will still be 'on' but the lights will be switch off
it works like the normal 2 way switch just that its now replace by ondicator.
as for heater LED
my master bathroom n common bathroom share same heater but can be turn on by the a switch outside the master bath or common bath (2 switches)
but heater works bit strange
if i turn on heater from my master bathroom, both LED lights will be on. then i must switch off at my master bathroom so that the LEG lights will be off.
but
if i turn on heater from my master bathroom, and i choose to switch off from common bathroom switch, this will cause prb. once i press the common bathroom switch, both LED lights will still be on
and now if i go to the master bathroom to try switch off, both LED lights will still be on...
I must go to common bathroom switch to off it first
then can switch off the LED from master bathroom
confusing...
so we need to switch on n off from the switch we on the heater
dunno if the electrician got hao siao us anot...
  ordix said:
Sorry i miss this reply. em... do u mean the ondicator or the heater LED switch???
Hi
I m referring to a normal 2 way 2 gang switch. Here is my setup, 2 gang 2 way - one for a room light and one for the foyer lighting. The foyer lighting onlys to switch on and off the foyer light. At the foyer lighting there are one dimmer switch but is not a 2 way switch function, only to switch on and off the light (one way function only).
When i switch on the 2 way 2 gang switch, there are no LED light on. However, at the foyer, the dimmer switch when switch ON, the LED light on.
The LED light are u referring to ondicator??
Edited by blackcar
  soxcotton said:
Cool! Nice switches!
May i know how much does 1 costs? Thanks!
I brought the dimmer switch at $141, ouch!!!. The price ranges from switches to socket estimated $18 to $60. Mine is sliver and bronze in color same as the above pics posted here.
  blackcar said:
Hi
bit confusing... ..the LED lights i refering to is the LED light of heater switch not the ondicator.
heater switch comes with a LED light
2gang switch zencello doesn't come with LED right?
the other model does. u using zencello?
err i think we r talking abt two different switches here. I m referring to the light switches not the heater switch. Is there heater switch for this model? I m using 20A switch instead, can you post a pic here? Mine is silver / bronze in color. Yap my hse are using Zencelo from clipsal.
Edited by blackcar
i see i see
yes yes its the 20A switch i am talking about.
it can be use for heater or lights i think
but mine is just 1 gang 2 way switch.
mine has lights leh...
em... maybe because yours is a 2gang?
  ordix said:
i see i see
Yes yes, as i mentioned previously 2 gang 2 way light switches no light on when it is switch ON.
cheers
Wow! That's really kind of X but the switches are really lovely! hehee :)
zencelo dimmer only sgd99 at choo jiang...
anyone know how to connect a zencelo 2 way switch?
just lets say there is location A and B.
Apparantly when I on A; I can off from B but I cannot on from A again ....
Werid.....
I got silver/grey colored ones from HK instead. Alot of colors not available in Sg. Also they started to change to Schneider Electric. hahaha. unique colors feel better mah. Anyway prices are similar to choo jiang in sg also. =) :yamseng:
  On 7/8/2009 at 1:10 AM, blackcar said:
<!--quoteo(post=420986:date=Jul 7 2009, 10:18 PM:name=ordix)--><div class='quotetop'>QUOTE (ordix @ Jul 7 2009, 10:18 PM) <a href="index.php?act=findpost&pid=420986"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->bit confusing... ..the LED lights i refering to is the LED light of heater switch not the ondicator.
the other model does. u using zencello?<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi All, just to share some info...I just went to Choo Chiang last week and confirmed the zencello does not have LED lights its just an indicator. Only the Clipsal Neo Series and Legrand Malia have the LED lights. Clipsal LED is blue while Legrand is either green or red. I bought Legrand Malia bcoz they are much cheaper than clipsal neo series and also prefer the green LED lights.
ncsl999
