jayleong99
Window Grills Quotation
I was quoted below for my HDB windows -
Aluminium 1 mm (with bar, non-hollow) - $8.80 psf,
Aluminium 2mm (with bar, non-hollow) - $11.80 psf
Wrought Iron (non-powder coating)- $15.80 psf
Do you all know if the qoutation is reasonable?
Anyone has a good grill contractor to recommend?
Thanks
Thanks
PMed you.
Hi rendell, can you PM me too as I'd like to install grills as well. Thanks!
PMed you.
Please note that this is not the cheapest contractor in town, but likely the most years experienced and top workmanship.
i.e No gap between grilles to wall, steady and no need maintenace, etc
Edited by rendell
PMed you.
Hi rendell... can PM me as well... interested in installing grilles for window..??
Thank you!!
Guest melancholic
Thanks
Can check Pang Giap Enterprise. They quoted me $6.5o psf for White powder coated Aluminium window grille - simple design PG008 which is just horizontal bars.. can check their website www.panggiap88.com.sg
Thanks
HI, My name is leslie Foo > My Company is LEGATE. We got some new products, to replace yourgrilles. Our Products LEGRILLES- Invisible Grllies is our latest . If interested you can call me at 9029-2925. Thank you
Best Regards,
Leslie foo :D
Best Regards,
Leslie foo :D
Invisible grilles? Interesting! U got any website to show the pics?
i did a search on the invisible grilles and found tis http://www.legate.com.sg/EnProduct.asp
it look interesting and i never seem something like tis in singapore but i tink the so-called grilles are made of those strong wires instead of aluminum bar. In this case the invisible grilles will be fixed unlike the usual aluminum grilles which u can still slide it to one corner when doing cleaning.
Edited by tulips
Hi all,
Got anyone just change all the window panels instead change the window frames for resale flat? Please advise. Thanks :)
Thanks & Regards
Hv try to rch them once, bt the way they talk ai mai ai mai like that...sianz... zz
U can try wellmax, their price is very competitive. i have asked around and the price is the lower among all and now the sales person gave me a special package price for windows and wrought iron gate which is very worth it.
Edited by tulips
They charged you how much? Care to share?
Thanks & Regards
The price which i got from wellmax for all the glass panels and grill with a wrought iron gate is around $3.2k. Green glass panel and silver grill, initally we wanted white powder coated grill but tat will cost an additional of $400... we got a tight budget so in the end we settle with silver. Other quotations I got ranged around $3.6k for the window only so the price which i got from wellmax is considered good becoz it include a wrought iron gate which cost at least $350 outside.
