mgbm
Electrical Quote Too High
can jaskel, please PM me our electrician contact. thanks in advance!
Hi everyone, just wondering if there is a diff in prices between Condo and HDB for electrical works done..
My ID quoted me ridiculous price- double of what I see in this thread so far :(
HDB - non concealed wiring. Condo - concealed wiring so more cost for hacking, relocate and plaster back.
Hi Jaskel,
Can i have the contact as well. Thank you.
HI Jaskel,
Could you pm me your electrician's contact details
Thanks
hi, pinkpetter and jaskel
pls provide me the contact no of your electrician to install lightings and add'l scv point for my place.
thanks
To all,
I'm not giving my electrician no. to anyone anymore. Cos my electrician complaint to me, he had been making wasted trips to owners' hse to give a quote and in return, most of them use the quotation to press down their contractors or ID electrical work pricing. So I see no point of recommend or passing the contact at all. In fact, I had tested it myself and most of the owners really do it this way, so it was a wasting of time for us to go down and quote.
This is the quote for my electrician, if the price is ok for u, then PM me, once my electrician goes down, is to sign quotation. If not, don't bother to ask for contact at all.
Lighting Point x 30
$25 x 30 = $750
1 x 13A power point x 3
$45 x 3 = $135
2 x 13A power point X 21
$50 x 21 = $1050
1 x 15A Air con point X 2
$90
TV point X 3
$90 x 3 = $270
Tel point X 2
$45 x 2 = $90
Data point X 4
$150 x 4 = $600
Door bell point & install X 1
$25
Cooker & hood point X 2
$80 x 2 = $160
Earth bonding (water & gas pipe) X 2
$180
Shift DB 15ft X 1
$90
New set 40A DB X 1
$320
Install cornices lighting X2 4
$10 x 24 = $240
Install ceiling lighting X 9
$10 x 9 = $90
Regards
jaskel
Edited by jaskel
Hi Jaskel,
Mine is Condo.
Please kindly list down the concealed costs for hacking, relocate and plaster back for power points, lighting point etc...
Thank you.
To all,
Lighting Point x 30
$25 x 30 = $750
$45 x 3 = $135
$50 x 21 = $1050
$90
TV point X 3
$90 x 3 = $270
Tel point X 2
$45 x 2 = $90
Data point X 4
$150 x 4 = $600
$25
$80 x 2 = $160
$180
Shift DB 15ft X 1
$90
New set 40A DB X 1
$320
$10 x 24 = $240
$10 x 9 = $90
Regards
jaskel
Hi Jaskel,
Mine is Condo.
Thank you.
Hack, relocate and plaster back 2 x New Down lighting point $80 each $160
6 x Looping point for downlight $25 each $150
Labour to change New 2G switch cover $8
Labour to install ceiling fan (item provided by owner) $35
Hack, relocate and plaster back 1 x new SCV point $150
4 x New Double SSO 13A power point $90 each $360
Hack, relocate and plaster back 1 x new Tel. point $90
Dining area
Hack, relocate and plaster 1 x New Lighting point for dining table $80
Hack, relcoate and plaster back 2 x New Single SSO 13A power point $80 each $160
Hack, relocate and plaster 1 x New Down Lighting point $80
1 x Looping point for downlight $25
Labour to change New 4G switch cover $8
Guest Room
Hack, relocate and plaster back 1 x New lighting point $80
Kitchen
2 x Looping point for downlight $25 each $50
Hack, relocate and plaster back 1 x New Dish Washer point $90
Hack, relocate and plaster back 3 x New Double SSO 13A power point $90 each $270
Hack, relocate and plaster back 1 x New Hood point $90
Labour to change 3G switch cover $8
Service Yard
Hack, relocate and plaster back 1 x New washing machine point $80
Maid Bathroom
Maid Room
Hack, relocate and plaster back 1 x New Double SSO 13A power point $90
Hack, relocate and plaster back 1 x New wall fan point $80
Labour to install 1 wall fan (item provide by owner) $35
Staircase
Hack, relocate and plaster back New LED strip point $80
Passageway (Level 2)
Hack, relocate and plaster back 1 x New Single SSO 13A power point $80
Hack, relocate and plaster back 2 x New wall light point $80 each $160
Bedroom 3
Hack, relocate and plaster back 1 x New water heater point $90
Bedroom 2
3 x Looping point for downlight $25 each $75
Kid's Bathroom
Hack, relocate and plaster back 1 x New mirror light point $80
Master bedroom
Master Bathroom
4 x Looping point for downlight $25 each $100
Loft Level
Others
Labour to install 45 lighting fixture $10 each $450
Not more than 10ft.
This is the quote for condo concealed wiring.
Electrician's work is very important, as some like to take short cut and did not lay the truncking nicely. Mine was quite badly done and is considering to touch up the mess.
Are you a condo or HDB? As HDB is not allowed to have conceal wirings.
I decided to use Jason's Electrician, will update on their workmanship in a few weeks time.
Hi Jaskel,
I'm interested to use your electrician for my renovation. Can you PM me his contact no. Thanks in advance!
I'm doing mostly spotlights in the rooms and living room. Will the charge be the same as installing a ceiling light?
Regards
bblurryy
To all,
Lighting Point x 30
$25 x 30 = $750
$45 x 3 = $135
$50 x 21 = $1050
$90
TV point X 3
$90 x 3 = $270
Tel point X 2
$45 x 2 = $90
Data point X 4
$150 x 4 = $600
$25
$80 x 2 = $160
$180
Shift DB 15ft X 1
$90
New set 40A DB X 1
$320
$10 x 24 = $240
$10 x 9 = $90
Regards
jaskel
I used Jason's electrician, today they have completed the cabling for the lighting, switches and sockets. I personally find their pricing is competitive and easy to communicate. I will give further feedback on their workmanship after the installation of downlight, switches and sockets.
Edited by casper
