lanesraki
5rm Partial Renovation Cost
Any good deal at Expo "modern living " show ??
how much for renovation works as below for my 5rm resale flat ;
2 toilets retiling , lay new floor and wall tiles.
Kitchen retiling + new cabinet .
living hall hacked marble floor ... lay 600mm x600mm homogenous tiles.
foyer partition panel + full height shoe cabinet
repainting whole house.
HUH why do you want to hack your marble flooring? Anything wrong with it? Can save some money by not hacking it.... what about overlaying with the tiles? if the marble is in good condition you can overlay.
Need dimensions to help you with the cost.
What is the size of your kitchen and the layout of your cabinets? How long? Top and bottom? tiling of walls or floor only?
2 toilets - when you say retiling is it overlaying it with new tiles or Hack off and retile?
need to know size of intended partition panel and shoe cabinet.
:) repainting should be between $1200-$1500 for 5 colours. Good if it can include repainting of everything + doors and pipes. :) Some contractors don't include.
Yup usually marble should be able to just do repolishing...unless you don't like the color/pattern of the tile?
because the most of the renovation costs are due to flooring and carpentry, you would be able to save quite abit; and some would say marble is quite ex so next time your flat would have a higher resale value.
and how old is your place? overlaying is not recommended for old houses as the waterproofing layer would have been worn off.
repainting is 1200-1600 for 6 colors, for 5 rm flat should be closer to 1500.
have any ideas on what concept you would like to pursue? modern?
my new resale place is abt 8~9yrs old with broken marble **** hall, some area , i check that there is some cracklines.... i had bad experience with my current place when i took over 5yrs ago ....also a resale house with broken marble, minor cracklines, i didnt care and just do polishing... to my horror ..after polished and chemical wash , crack or bigger and chipped off alot portion....
i will need to check my floorplan for size of kitchen.
toilet i wanna hack off and lay new tiles..
Whoa you've had bad experience before.. no wonder scared now.
My toilet hack off all tiles and relay+ waterproofing cost about $1500 each. :) (but i renovated the whole house...) Tiles go up to $3 each and I added some mosaic in one.
If you are considering wood (e.g. parquet) flooring for your house or you have existing wood flooring to maintain, I can provide recommendation which you can save some money by working directly with the wood flooring specialist (reduce middle man markup).
If you are interest, you can email me at alfred.cheong@live.com
Actually, u can do patching. It will prevent the cracks from getting bigger n not easily seen. It do save a few K to redo the flooring.
if wan you also can try my lobang quite reliable also, pm me to get it. before doing your house i think you should just get another second opinion, anyway you nothing to lose in getting another quotation to compare.
heres the pictures & story of my redone house by the reliable contractor:
http://www.renotalk.com/forum/index.php?showtopic=20227
TRUST ME YOU WON'T REGRET. been there done that =)
P.S. add me if msn: cord_des@hotmail.com if you want to
