werty
Using Hd Projector As Tv
Hi all...
Newbie here....Wondering anyone using HD projt as TV? Any recommendations? I used to play projt (non HD) type on my previous home....now getting resale flat few months time..had lost touch on projt updates, so hope forummers here could advise....
Thanks and cheers.... :yamseng:
Well, there are a couple of things you might want to take note.
Viewing Distance
Optimal viewing distance has always been a criteria for folks who are fussy and want to have a good viewing distance to the screen. You might want to check here to calculate what's an optimal viewing distance to your screen.
For a simplified version of size and distance, click here
Lumens
Screens < 80 inches diagonal : Recommended 1000-2000
Screens between 80-120 inches diagonal: Recommended 2000-3500
Screens > 120 inches : Recommended 3500 or more
Unfortunately, if you can control your lighting because projectors typically need a dimmer lighting, then you need to get higher lumens.
Lamp Life
Generally lamps nowadays can last around 3000hours
So estimating around 6hrs a day everyday, you can wait till another 1 year 5 months before changing a new lamp which could cost another few hundred dollars.
One drawback is the lack of video input options as compared to LCDs or Plasma TVs.
Watching HD for television is really an overkill in my opinion unless you watch bluray etc..
I don't understand your question can you give me some details for this?
I need recomendations on make and model of HD projt, specs and prices. possible plc to get them...my apologies for not making clear...
cheers
Viewing Distance
Lumens
Lamp Life
hi Phatom,
Thanks for the info...currently u using one? appreciate if u could share the make and model...
Thanks again....
cheers
hi Phatom,
Thanks again....
I'm not using one. Sorry.. did not want to use a projector in my case.
Cheers and Gd luck.
