ultramantaro
3 Rooms Renovation
Hi anyone:
I would like to know if my contractor quoted me are reasonable.
Please see the renovation items listing
Design Services Amount S$
Space planning and furniture layout
Design consultation, materials and colour proposal F.O.C
Site supervision
Application of permit from HDB or relevant authorities
Dismantling/Hacking Work
Hack existing concrete sink support $150.00
Dismantle existing kitchen cabinet $250.00
Hack kitchen entrance wall & make good $350.00
Hack existing skirting for whole house flooring & make good $250.00
Masonry Work
Supply and overlay designer ceramic floor tiles at kitchen $1,050.00
Construct kitchen cabinet base $280.00
Hack and relay kerb at main door entrance $150.00
Plumbing and Electrical Work
Re-wiring for whole house c/w 20 downlight point & MCB board $1,900.00
Replace existing pipe to stainless steel piping for whole house (cold water only) $600.00
Connect in/outlet for sink & wash machine F.O.C
Painting and Cornices Work
Supply and install L-Box cornices **** room $540.00
Supply and install gypsum board wall **** room $180.00
Supply and install L-Box cornices at bedroom 1 $450.00
Supply and install gypsum board feature wall at bedroom 1 $350.00
Supply and install false ceiling at bedrooms entrance $150.00
To seal up ventilation above door for 2 bedroom $180.00
Supply and plaster compound smooth for whole house interior wall and ceiling $1,350.00
Supply and painting whole house interior wall and ceiling with ICI Dulux pentalite paint $950.00
Painting inclusive doorframe and pipeline $-
Carpentry Work
Design and fabricate 20ft length laminated kitchen cabinet come with ABS trimming $2,000.00
Supply and install 10ft Solid Surface kitchen worktop $700.00
Design and fabricate 1 set 6ft length laminated glass sliding wardrobe $1,680.00
Design & fabricate 9ft length laminated door & frame below window for bedroom 1 $900.00
Supply & overlay laminated wood flooring for Dining & Living room with platform @area 65sqft/200sqft $1,850.00
Supply & overlay laminated wood flooring for bedroom 1 $500.00
(above laminate wood flooring used Supreme laminate floor brand)
Supply & install 2 set solid Nyatoh ply veneer finish bedroom door $360.00
Supply & install Nyatoh ply veneer finish main door $480.00
Miscellanous Work
Debris removal fees & floor protection $350.00
Provide chemical wash for whole house wall and flooring tiles & general cleaning $250.00
HDB permit submission fee F.O.C
Maybe you can tell me which can be further bargain down.
Thanks
I suggest you go for a 2nd (or even 3rd) contractor to give you another quote to do comparison - is free and no obligation.
I see that your contractor quote you laminate flooring.
Both laminate Flooring and solid wood flooring have their pros and cons but usually if you do not mind paying more, solid wood is the preference to compressed wood. Beside solid wood flooring allow you to do refurbishment (restoration by grinding the surface), which can be seen as a better long term investment.
If you are considering wood (e.g. parquet) flooring for your house, I can provide recommendation which you can save some money by working directly with the wood flooring specialist (reduce middle man markup).
If you are interest, you can email me at alfred.cheong@live.com
Hi anyone:
Site supervision
Masonry Work
Carpentry Work
It is top and bottom? If yes, then 10ft top, 10ft bottom, u got a very small kitchen. If no, then the cost will come in later. Now all cabinet come with ABS trimming already.
Miscellanous Work
Thanks
I think it the contractor missed out somethings and when u engaged him to do, he will surely add in things that u need and u have no choice.
U can try some more contractors quotation first.
I have a good carpentry to intro. My HDB hse carpentry were done up very nice and good workmanship. Somemore got after sale service.
She was a very nice young lady who helped me to design and give advise (that y I didn't need to engage any ID(save cost)). Moreover will add things in for FOC as she just want the design to look even nicer.
Presently, engaged her to do my condo.
if want try my lobang. heres the pictures of my kitchen cabinet and toilet:
http://www.renotalk.com/forum/index.php?showtopic=20227
pm me if you wan his contact, trust me he's reliable. ALWAYS GO FOR A FEW MORE QUOTATIONS. and whens it is too cheap, check materials from where and quality too.
P.S. add me msn: cord_des@hotmail.com if you want to
You should get three quotes and compare don't hire the cheapest contractor. just compare and make sure that all contractor are pricing you specificly for the same projects.
Guest poetsdesign
Maybe you also need some picture from the contractor
and compare all of them
