hihihi
How To Service A Instant Water Heater?
Bought a new water heater, after install, it works fine for few mths. After that it just died.
- tested, wire is still alive
- power LED indication doesn't lid
- water is cold = no heatinng
Still under warranty, but Elmark wants to charge me $50 if it's my wiring fault. And also charge me $30 if it's their equipment fault.
attached is a pic of my instant water heater internal part. Can advise me which part is most likely faulty and needs to change? If possible I would want to self service.
Edited by hihihi
Try replace the power Socket fuse(13amp)...
the grey colour wire comes in from the top is direct from outlet point, so there's no plug involve, therefore no fuse. Grey colour wire comes in, Live/Neutral/Earth, I tested the wire, it's still 'live'.
Use another wire to connect(Remove the grey colour wire comes in from the top) direct to to heater unit, see got power...!
