lynglyng
Help! 4rm Resale (100sqm) Reno Quote
Pls can anyone experienced help me with the below quote to see if pricing is reasonable/steep? :help:
-Supply & Lay ceramic wall tiles (ceiling hgt) for 2 Bathrooms $2800
-Supply & Lay Homogeneous (600 x 600) floor tiles with skirtings for Living & Dining Room $2070
-Fabricate & Install aluminium sliding & casement Window with glass panels for whole unit $3100
-Design & Fabricate 40ft top/bottom Kitchen Cabinet $4000
-Supply & Install colour glass for kitchen cabinet backing $600
-Design & Fabricate 5ft wall mounted Shoe Cabinet with aluminium frame & mirror casement door
$1250
-Design & Fabricate 10ft wall mounted Study table with drawers $1400
-Design & Fabricate King-size Bedhead& Bedframe in PVC finish with glass side table $1600
-Design & Fabricate full-height 18ft open wardrobe in polygem internal finish $3570
-Suppy & Overlay Laminate Flooring with skirtings at Master Bedroom & 2 Bedrooms $1800
-Supply & Construct 100mm hgt laminate Platform in Master Bedroom $1300
-Supply & Install 10mm thick frameless tempered glass shower screen with sliding panel at 1 bathroom
$750
-Supply & Install 10mm thick frameless tempered clear glass fix panel & swing panel for kitchen entrance
$1120
Thanks a mil!..... :thumbs up:
You must get your contractor/ID to indicate price of the wall and floor tiles, the max amount you are entitled to choose. Now may look cheap but if they tell you can only choose tiles below $2.50psf, that's very risky cuz the nicer tiles we saw ranges between $3psf to $3.80psf. You may have to top up quite a bit if that's the case.
Windows quite expensive. Mine whole house plus wrought iron for living and common about $2,200. And tempered glass shower screen at common at $550.
But carpentry pricing looks okay.
Wall & floor tiles all quoted at $3/psf. Your windows is aluminium sliding with glass panels for living and 3 bedrooms?
Yes - mine is aluminium sliding for living, kitchen, 2 bedrooms and 2 toilets. Changed all, except wrought iron for only living and common/guest room.
hmm, mine's without grilles. only the sliding windows. you have any pics of your hm to share?
Have you started you renovation already?
I see that your contractor quote you laminate flooring.
Both laminate Flooring and solid wood flooring have their pros and cons but usually if you do not mind paying more, solid wood is the preference to compressed wood. Beside solid wood flooring allow you to do refurbishment (restoration by grinding the surface), which can be seen as a better long term investment.
If you are considering wood (e.g. parquet) flooring for your house, I can provide recommendation which you can save some money by working directly with the wood flooring specialist (reduce middle man markup).
If you are interest, you can email me at alfred.cheong@live.com
$1250
$750
$1120
Hi lynglyng,
Your contractor charges for carpentry are very reasonable.
May I have the contact? Is he good?
Hi lynglyng,
I also have a good carpentry to intro. My hse carpentry were done up very nice and good workmanship. Somemore got after sale service.
She was a very nice young lady who helped me to design and give advise (that y I didn't need to engage any ID(save cost)). Moreover will add things in for FOC as she just want the design to look even nicer.
Now engaged her to do my condo.
if wan you also can try my lobang quite reliable also, pm me to get it. this contractor, hes an interior designer himself, he BAO KA LIAO ONE. lol
so why not just get another second opinion, anyway you nothing to lose in getting another quotation to compare.
heres the pictures & story of my redone house by the reliable contractor:
http://www.renotalk.com/forum/index.php?showtopic=20227
TRUST ME YOU WON'T REGRET. been there done that =)
P.S. add me if msn: cord_des@hotmail.com if you want to
Edited by lObAnGkInG
