yapwilliam 0 Report post Posted December 9, 2008 Hi all, I would appreciate if any1 could kindly advise me on my quote of my 4rm resale flat. A. Demolition Work – hack off existing 1. Wall tiles at kitchen & 2 bath 2. Floor tiles at kitchen & 2 bath 3. Existing motar base at kitchen 4. Floor tiles & skirting **** hall, 3 bedrooms & storeroom 5. Built-in wardrobe in MBR 6. Stove & Sink support 7. Wall panel-in between Master room & master bath B. Wet work – supply & lay 1. Wall tiles at 2 bath room ($2.00-2.50/ft) $2142.00 2. Floor tiles at 2 bath room ($2.50-3.00/ft) $1000.00 (At 2:50psf this presumes that wach bathroom is about 200sqft. Seems like very big bathrooms. 3. Cement screed & tempered glass backing along top & bottom cabinet $1556 (not sure what this is) 4. Floor tiles at kitchen ($2.50-3.00/ft) $1000.00 (This quote assumes your kitchen is about 350-400sq ft also very big) 5.Construct shower kerb at master bath $90.00 (ok) 6. Water proofing at kitchen & 2 bath $380.00 (Ok) 7. Construct fridge base & cabinet base & washing machine base at kitchen $450.00 8. Homogenous floor tiles c/w skirting **** hall, 3 bedrooms & store ($2.80-3.00/ft) $3970.00 (Assuming $3/ft then your bedroom + living hall + store is 1323sq ft) This seems a bit big for a four rm flat. This also does not inlcude the floor area occupied by kitchen and toilets and wash area etc) 9. Raise flooring c/w polyform at dining hall c/w homogenous floor tiles c/w skirting ($2.80-3.00/ft) $650.00 (cannot comment) 10. Raise platform at Foyer area $750.00 11. Cement screed to make good new dining hall $550.00 12. Construct 63mm hollow block wall panel in-between a. New dining hall & kitchen c/w lintor beam $500.00 b. Master room & master bath $250.00 13. Patch up wall to make good hacking area $300.00 14. Construct 63mm hollow block L-wall panel c/w wall tiles to conceal pipes at master bath $150.00 C. Carpentry work – ABS trimming in solid ply & laminate finishes, internal in white PVC, supply and install 1. Kitchen a. Kitchen cabinet top: 9ft bottom:9ft x 5 ft $2215.00 b. Partition along kitchen sink $180.00 c. solid surface c/w backsplash at kitchen work top 9ft x 5ft $980.00 d. stainless steel dish drainer FOC e. installation of cooker hood & hob FOC 2. Master room a. Full ht sliding wardrobe 6ft $1260.00 (reasonable) 3. Master bath a. Suspended vanity top c/w $880.00 i. Alum sliding door c/w alum frame & frosted glass panel ii. Solid surface c/w backsplash iii. Full ht mirror iv. Light plemet 4. Living Hall a. Full ht shoe cabinet c/w settee 4.5ft $840.00 b. Full ht TV console c/w 6ft $1900.00 i. Features backing ii. Suspended drawer iii. Pull out tray iv. Drawer v. DVD compartment D. Doors, gate, shower screen & rubbish chute – supply & install 1. Alum bi-fold door at common bath $220.00 2. Wrought iron main gate $450.00 3. Tempered glass swing door c/w fix panel at in-between new dining hall & kitchen $750.00 4. L-shaped alum sliding glass shower screen c/w fix panel at master bath $600.00 5. Stainless steel rubbish chute at kitchen $220.00 E. Wall plastering, painting & partition 1. Supply wall plastering for whole unit c/w corner beat $1500.00 2. Supply & paint with ICI emulsion paint for whole unit c/w sealant including doors, door frames & pipes $1250.00 3. False ceiling c/w light holder **** hall $1050.00 4. Partition divider c/w frosted glass panel at master room $580.00 5. False ceiling c/w light holder at master room $600.00 ( Make sure it is for the whole of the master bedroom and not just an L-box. ) F. Plumbing work 1. Supply and replace stainless steel piping for whole unit and hot & cold water at 2 bath shower only $1010.00 2. Installation of kitchen sink $60.00 3. Installation of water tap at kitchen sink FOC 4. Supply and install inlet and outlet pipe at kitchen sink FOC 5. Installation water tap for washing machine FOC 6. Supply and install inlet and outlet pipe at washing machine FOC 7. Installation of basin at 2 bath room $120.00 8. Installation of basin tap at 2 bathroom FOC 9. Installation of gallon heater at 2 bathroom $60.00 10. Convert squatting pan to sitting pan $180.00 11. Installation of toilet bowl at 2 bath $180.00 G. General work 1. HDB permit FOC 2. acid cleaning FOC 3. Haulage $450.00 4. debris disposal $380.00 Grand total: 33438.00 After discount: 33000 Share this post Link to post Share on other sites
pinkpetter 0 Report post Posted December 9, 2008 mm do you have a floor plan? Can put up? Why is your toilet so big... My toilets are about 132sqft in total and using $3/sqft tiles... My floor tiles + waterproofing cost $800 My Wall tiles cost $2200 If your tiles are only $2.50 they should cost much less? And my waterproofing is included which I noticed you have a $380 charge for. And ah your kitchen cabinet is 9ft in total? So it works out to be $246/ft? Mine is $90/ft.... Even if your kitchen cabinet is 18ft it still works out to be $130/ft which is ex... mm As for the Haulage mine was combined with debris and cost me $280 in total. ... Other things.. cos you have a lot of carpentry... it makes everything more ex ba. Share this post Link to post Share on other sites
de_Pierre 0 Report post Posted December 9, 2008 (edited) Is urs a HDB 4rm???? Kitchen 350sqft + toilets 200sqft + Living/Dining, 3 bdrms n store 1323sqft = 1873sqft Ur 4rm flat is 1873sqft = 170 square metres!!!! There's too many 'give n take' in ur quote... Some seems unbelievable cheap, some is sky high wor... COMPLICATED!!! (maybe its a quotation from a 'newbie') Edited December 9, 2008 by de_Pierre Share this post Link to post Share on other sites
yapwilliam 0 Report post Posted December 11, 2008 Hi all, Thanks to everyone for taking time to read the lengthy quotation. My house floor plan dimension is as follows, please pardon me.... i dun really know how to convert psf etc. Dimension in Square feet Kitchen = 223.18 Common toilet= 31.97 MBR toilet = 27.13 MBR = 81.38 Bedroom1 = 135.64 Bedroom2= 138.87 Living room = 269.97 Storeroom = 27.28 On a separate note, any kind soul please PM me your contractor/ID contract who quote more reasonable price than this. Share this post Link to post Share on other sites
de_Pierre 0 Report post Posted December 11, 2008 Its actually very simple... Costings divide by total area in sqft = psf charges liao... Share this post Link to post Share on other sites
poshluv 0 Report post Posted February 15, 2009 Hi all, Thanks to everyone for taking time to read the lengthy quotation. My house floor plan dimension is as follows, please pardon me.... i dun really know how to convert psf etc. Dimension in Square feet Kitchen = 223.18 Common toilet= 31.97 MBR toilet = 27.13 MBR = 81.38 Bedroom1 = 135.64 Bedroom2= 138.87 Living room = 269.97 Storeroom = 27.28 On a separate note, any kind soul please PM me your contractor/ID contract who quote more reasonable price than this. can PM me too at poshluv@hotmail.com .. thanks! so hard to find reasonable quotes nowadays Share this post Link to post Share on other sites
