sheringam 0 Report post Posted November 22, 2008 I have just removed the lighting wirings inside the PVC trunking which has not been used for more than 10 yrs. I need to remove the PVC switch as well. But the problem is that white PVC switch is nailed onto the wall using concrete nails and I do not know how to remove them. Share this post Link to post Share on other sites
yoongf 11 Report post Posted November 22, 2008 No way to cleanly remove them. Is to use flat scewdriver and hammer/wedge them out, which means the PVC box also will get spoilt. Then need to use putty and paint to cover up any holes/ scar marks. U can try using a hammer and screwdriver and hammer the nail loose, but that is likely to create more cracks. Share this post Link to post Share on other sites
hihihi 0 Report post Posted November 22, 2008 easier way perhaps can wack that nail further in and plaster it over. Share this post Link to post Share on other sites
