alphakim
Help To Check Whether This Contractor Offer Expensive?
Hacking Work
1. Supply and tools to hack off existing cabinet and concrete support at kitchen
2. Supply and tools to hack off 2 toilet bowls and 1 basin
3. Supply and tools to hack off 2 bathroom doors and frame
Masonry
1. Overlay common and master bathroom floor
2. Provide polish 400sqft marble flooring
Kitchen Cabinet
1. Fabricate and design 20 feet (Top + Bottom) kitchen cabinet using solid plywood with laminated finished ABS trimming.
2. 1 pair frosted glass cabinet door panel with frame
3. Stainless steel handles
4. 1 set dish rack with drainer
5. 10 feet solid surface top w/50mm backsplash and 38mm front profile
6. Provide 1 set stainless steel double bowl sink with lever tap
7. Provide 1 set cooker hood (cuizino)
8. Provide 1 set cooker hood (cuizino)
9. Supply connect cooker hood and hob
10. Supply inlet and outlet water piping for sink
11. Provide haulage and debris disposal service
Plumbing
1. Install 2 toilet bowl (OTTO)
2. Install 1 basin (OTTO)
Doors
1. Install 2 aluminium frame and bi-fold doors
Miscellenous
1. Acid wash kitchen and toilet
Total Damage: $7,000
Edited by alphakim
1. Supply and tools to hack off existing cabinet and concrete support at kitchen...
Behind the cabinet got many wall-plug holes, concrete support hacked off, wad happens to the wall tiles?
No quotes, meaning jus leave it undone?
2. Fabricate and design 20 feet (Top + Bottom) kitchen cabinet using solid plywood with laminated finished ABS trimming.
Ur cabinet only 20ft? Any idea how much they'll quote for additional cabinet PFR leh???
For the first question, we will ask them to place back the wall tiles if neccessary. We have existing tiles with us.
As for cabinet, they calculate $95/ft for additional run.
Hi there can pm me ur contractor. i intend to do the same as urs.
thks
can TS pm me contractor.
where can I find $7000 for reno Kitchen cabinet + feature wall and tv console.
Is the below quote for reasonable. Can anyone recommend me Contractors/ID email for me to email them.
1.Fabricate 8ft feature wall c/w laminate finishing & design **** area., $1,200.00
2.Fabricate 8ft open T.V console c/w laminate finishing., $800.00
3.Fabricate 6ft casement door wardrobe c/w ABS trimming,handle & laminate finishing for both bedrooms, $2,640.00
4.Supply labour to dismante both toilet basin & w.c bowl., $80.00
5.Fabricate 30ft casement door cabinet c/w ABS trimming,handle & laminate finishing., $3,300.00
6.Supply labour & material to install 15ft soild surface top c/w black flash & profile., $1,200.00
7.Supply labour to install 2nos of basin., $130.00
8.Supply labour to install 2nos of w.c bowl., $160.00
Total $95XX
Total $95XX
The feature wall + console + kitchen this contractor quote isn't within your budget? It consider reasonable.
Yup it is reasonable.
The most you can ask is another 5-10% discount... they need to earn too.
