jasoncassanova
Bathroom Flooring
Can be slate tiles, ceramic tiles, homogenous tiles, etc... Jus go to any tiles supplier saying u're looking for tiles for wet areas, they'll guide u along... All tiles r durable, only depends on ur maintainance...
Mostly tiles used for wet areas r in matt finishings...
as for the bathroom tiles its better to use 300mm by 300mm
as they have better gradient compared to the 600mm by 600mm one.
so water will not be trapped there
i'm sorry i don't understand this, is it because the 300mm x 300mm is bigger in size? or is it more flat?
Would you all use colored (i.e. grey color/ black color) tiles for bathroom floor? or white tiles are fine (slightly more difficult maintenance)?
Hope u all can share. I'm in dilemma to use grey or to stick to white for both bathroom floor....thanks
hi all,
we had the same dilema for the bathroom tiles.
After 2 years of use, perharps our sharing can help you to make an informed decision.
our situation is:
Common toilet: dark colour tiles, very rough
MBR toilet: light colour tiles, but slippery.
see photos
our general findings are:
1. Colour does not affect maintenance much (staining from a drying moist floor)
2. we found what affects maintenance is
a. roughness of tiles. rougher tiles are harder to clean as they tend to trap soap and skin cells.
b. clearing off water the floor after every bath is much more efficient than the weekly hard scrubbing.
c. use 300mmx300mm tiles to allow the tiler to create a better slope to drain water into the outlet pipe.
