fengshui-123 0 Report post Posted December 2, 2008 not sure whether the top of your google earth map pointing to North exactly, if it is then your house accurate direction is as shown below: refer to: http://www.renotalk.com/forum/index.php?showtopic=18302 Share this post Link to post Share on other sites
ppgohbk 0 Report post Posted December 3, 2008 (edited) Hello Yes, that is the position which is beside shoe box. The way the Qi moves outside your house is not good. Doing as I suggeste will help to redirect the Qi. okay for the plant location but any particular date to put it ? thanks Edited December 3, 2008 by ppgohbk Share this post Link to post Share on other sites
Mr Chong 0 Report post Posted December 4, 2008 okay for the plant location but any particular date to put it ? thanks Hello Use Sat 3pm Share this post Link to post Share on other sites
ppgohbk 0 Report post Posted December 5, 2008 Hello Use Sat 3pm noted, thanks Share this post Link to post Share on other sites
ppgohbk 0 Report post Posted December 8, 2008 Mr. Chong, I had put the plant as stated but the house owner shift it back to my place the very next day Any other alternatives of good place to put ? Share this post Link to post Share on other sites
Mr Chong 0 Report post Posted December 8, 2008 Mr. Chong, I had put the plant as stated but the house owner shift it back to my place the very next day Any other alternatives of good place to put ? Hello Your exterior west is blocked by another building or solid vertical wall? Afternoon quickly put some metalic display/objects in both your toilets and service balcony. Keep all the windows at these locations open. Keep your kitchen door close. The partition (you erected) within your foyer area, place an indoor plant at the edge (opposite the wall side) forming an L-shape. So that when you enter your main door and turn right, the space is smaller. Understand? Share this post Link to post Share on other sites
Diavonex 0 Report post Posted December 8, 2008 Is the missing sector near the balcony a problem? Share this post Link to post Share on other sites
ppgohbk 0 Report post Posted December 9, 2008 (edited) Hello Your exterior west is blocked by another building or solid vertical wall? Afternoon quickly put some metalic display/objects in both your toilets and service balcony. Keep all the windows at these locations open. Keep your kitchen door close. The partition (you erected) within your foyer area, place an indoor plant at the edge (opposite the wall side) forming an L-shape. So that when you enter your main door and turn right, the space is smaller. Understand? Hi Mr. Chong, done with all the above except the plant as I want to ensure the actual position with pictures. ( A or B) Do I still need the fish tank outside ? My exterior west sector is another unit's balcony, another building is quite far apart. here is a sectional building view...mine is 383 Edited December 9, 2008 by ppgohbk Share this post Link to post Share on other sites
fengshui-123 0 Report post Posted December 9, 2008 (edited) see my suggestion. Edited December 9, 2008 by fengshui-123 Share this post Link to post Share on other sites
Mr Chong 0 Report post Posted December 13, 2008 Hi Mr. Chong, done with all the above except the plant as I want to ensure the actual position with pictures. ( A or B) Do I still need the fish tank outside ? My exterior west sector is another unit's balcony, another building is quite far apart. Hello I suggest that you take on one advice at a time. Try the suggestion by the other forumer first. It would not be good nor appropriate to mix one method with another. Hope you understand. Share this post Link to post Share on other sites
