i just went to a lighting shop just now.
each plc down light made in taiwan but inside part like the ballast is made in austraillia
each cost 38 bucks.
normal 4 inch plc can use max is 13 watt
normal 5 inch plc can use max is 18 watt
normal 6 inch plc can use max is 26 watt and bla bla bla.
okie ma?
cheers
then led light not bad also. each light cost abt 120 bucks
but the light need to change only after 6 to 7 years
cheers, Ching
NEVER buy a downlight that comes with ballast.
easier to change a blown bulb than to change the ballast.
$10 - $30. mine with stainless steel casing + bezel only $15.
get one without ballast - just screw in a energy saving bulb.
Mace ...
can pm me where to buy the downlight only at $15
(the one without ballast)
thanks in advance :)
For a 4-RM (94sqm), i am getting 10 units of square downlight for the living room [7100 (L) x 3450 (W)] which is a rectangle shape.
Wondering if a 13 watt square downlight is sufficient or 18 watt square downlight?
Can anyone advice?
Thanks.
Mace ...
Can anyone advice?
Thanks.
1. 13 or 18 w is no good enought. PLC has "disfussor" so light emits to cover a limit round-area. I used all "white light".
2. Use those 2 x 13 watt = 26watt PLC. My 5-rm pt blk's hall fitted with 4+2+3 = 9 such with 3 switches. Folyer=1 such + 1 switch.
3. Dinning area with 6 such, 3 switches.
4. Study area with 6 such, 2 switches.
5. Son's rm, 4 such, 2 switches.
6. Daughter's rm, 4 such, 2 switches.
7. Master's rm, 6 such, 3 switches.
Edited by bepgof
Will it be too bright?
13W it enough, but again depend on hw bright u expecting.
Near missed to reply. Never too bright. The key is to install "a few" switches for a room, or a particular area. So one can control.
My precious condo applied the same concept.
Note: Nice to install "warm light" for romantic/soft ambience, but no good for reading.
Edited by bepgof
