burgess 0 Report post Posted August 4, 2008 My wooden toilet door wouldn't close properly, possibly because of some moisture damage which has caused the wood to warp at the bottom; it get progressively tighter and harder to close as i move it towards the doorframe. Other than that, there is really nothing visible to suggest any damage. 1. So can i get it repaired 2. If not, how much would it cost to replace it and any body can recommend a door maker? thanks Share this post Link to post Share on other sites
LittleDevil 0 Report post Posted August 10, 2008 My wooden toilet door wouldn't close properly, possibly because of some moisture damage which has caused the wood to warp at the bottom; it get progressively tighter and harder to close as i move it towards the doorframe. Other than that, there is really nothing visible to suggest any damage. 1. So can i get it repaired 2. If not, how much would it cost to replace it and any body can recommend a door maker? thanks i think you should simply replace it. A normal bi-fold door is only about $200. Better than repair and then after a while the same problem resurface. Timber and water don't go well together... Share this post Link to post Share on other sites
explorers 0 Report post Posted August 11, 2008 will laminating the door prevent warping? that is if it hasn't happen yet. Share this post Link to post Share on other sites
