typhoonz 0 Report post Posted July 23, 2008 (edited) Here's a description of my quotation. My house area is 103 sqm (4A) 1 Specialized Work : a) Provide consultation on design concept & services by designers b) Provide consultation on selection & usage of materials by Designers c) Provide consultation on selection of lighting, accessories & furnishing materials by Designers d) Provide site co-ordination during the process of renovation work 2 Demolishing works **** hall /Dinning hall /Bedroom area /Balcony : a) Demolish existing 3nos doors b) Demolish existing main gate c) Demolish existing living hall & 3 room's windows and grilles d) Demolish existing cornice **** hall e) Demolish existing arch at kitchen entrance f) Dismantle existing divider **** hall g) Demolish existing cornice at 3 bedrooms h) Dismantle existing wardrobe at master bedroom I) Dismantle existing laminate flooring at master bedroom j) Dismantle existing wardrobe at bedroom 2 k) Dismantle existing carpet at bedroom 2 l) Dismantle existing wardrobe at bedroom 3 3 Carpentry works at Master bedroom : a) Supply & install 8ft design sliding wardrobe with laminate finish 4 Carpentry works at bedroom 3 : a) Supply & install 6ft design wardrobe with laminate finish 5 Demolishing works at Kitchen area : a) Dismantle lower kitchen cabinet b) Dismantle upper kitchen cabinet c) Hack off kitchen existing cement sink support d) Hack off kitchen existing cement cooking support e) Hack off kitchen existing wall tiles f) Hack off kitchen existing floor tiles and cement mortar g) Hack off kitchen existing 50mm cement base h) Chipping kitchen top existing wall I) Remove existing rubbish chute 6 Construction wet works and plumbing works at Kitchen area : a) Supply & apply 104 quick seal flexible chemical cementitious to waterproof flooring to prevent water leakage b) Supply & lay country ceramic tiles for kitchen flooring c) Construct of 50mm cement mortar washing machine base with country tiles finishing at kitchen area d) Supply & install PVC drainage piping for kitchen sink and washing machine with gully floor trap e) Construct of 50mm cement mortar fridge base with country tiles finishing f) Construct of 50mm kitchen cabinet cement mortar base with country tiles skirting finishing g) Supply & install new aluminum rubbish chute (flat type) h) Construct low wall using H/B with country tiles finishing i) Wall washing /Cement tamping /Chemical cement plastering /Cement plastering and leveling kitchen wall and patch up smooth j) Supply & lay wall tiles(9ft X 3ft) in between top and bottom kitchen cabinet k) Supply & lay (heavy duty) Ceramic skirting at kitchen area l) Supply & install stainless steel piping for kitchen sink and washing machine (All water inlet c/w stop-cock) m) Provide labour to install sink & tap 7 Carpentry works at Kitchen area(24ft) : a) Supply & install 1 no. of L-shape bottom cabinet with laminated surface and ABS trimming finish include hinges b) Supply & install 1ft(L) full height tall cabinet to box up PVC sewage pipe with laminated material and ABS trimming finishing c) Supply & install 1 no. of top cabinet with laminated surface and ABS trimming finish include hinges d) Supply & Install 1 set of lower cabinet drawer in laminated surface finish e) Supply & install 1 no. of cutlery tray f) Provide labour to install cooker & hob 8 Supply & Install 01 no. of stainless steel dish tray 9 Supply & Install 01 no. of 13ft solid surface work top 10 Demolishing works at Common toilet : a) Hack off existing wall tiles and cement screed b) Hack off existing floor tiles and cement mortar c) Chipping top existing wall d) Remove existing WC e) Remove existing toilet door 11 Construction wet works and plumbing works at Common toilet : a) Supply & apply 104 quick seal flexible chemical cementitious to waterproof flooring to prevent water leakage b) Supply & lay country tiles for toilet flooring c) Cement tamping / chemical cement plastering and leveling toilet top wall before lay wall tiles d) Supply & lay wall tiles at toilet wall up to ceiling height e) Provide labour to install toilet WC (squatting to sitting) f) Provide labour to install toilet basin g) Provide labour to install toilet accessories h) Provide labour to install storage heater i) Supply & install new hot & cold stainless steel piping j) Construct main kerb include grinding edge finishes 12 Demolishing works at Master toilet : a) Hack off existing wall tiles and cement screed b) Hack off existing floor tiles and cement mortar c) Chipping top existing wall d) Remove existing WC and basin e) Remove existing toilet door 13 Construction wet works and plumbing works at Master toilet : a) Supply & apply 104 quick seal flexible chemical cementitious to waterproof flooring to prevent water leakage b) Supply & lay country tiles for toilet flooring c) Cement tamping / chemical cement plastering and leveling toilet top wall before lay wall tiles d) Supply & lay wall tiles at toilet wall up to ceiling height e) Provide labour to install toilet WC and basin f) Provide labour to install toilet accessories g) Supply & install new hot & cold stainless steel piping h) Construct main kerb include grinding edge finishes 14 Cornices/False Ceiling works : a) Supply & install false ceiling **** hall b) Supply & install false ceiling at kitchen passage way c) Supply & install false ceiling at bedroom passage way d) Supply & install false ceiling at master bedroom e) Supply & install L-Box at bedroom f) Supply & install false ceiling at bedroom g) Supply and plaster kitchen existing ceiling to smooth finish 15 Aluminum works (white powder coated colour frame c/w normal glass) : a) Supply & install 1no of adjustable louver windows (frosted glass) at common toilet(4ft X2ft) b) Supply & install 1no of adjustable louver windows (frosted glass) at master toilet(4ft X2ft) c) Supply & install sliding windows at kitchen d) Supply & install 1set of sliding windows **** hall e) Supply & install casement windows at master bedroom f) Supply & install 1set of sliding windows at bedroom 2 g) Supply & install casement windows at bedroom 3 h) Supply and install aluminum grilles at kitchen i) Supply and install aluminum grilles **** hall j) Supply and install aluminum grilles at master bedroom k) Supply and install aluminum grilles at bedroom 2 l) Supply and install aluminum grilles at bedroom 3 m) Supply & install 01 set of powder coated aluminum bi-folding door at common toilet n) Supply & install 01 set of powder coated aluminum bi-folding door at master toilet 16 Wooden doors : a) Supply & install 01no.of nyatoh door c/w key lock for store room b) Supply & install 03nos.of nyatoh door c/w key lock for bedrooms 17 Wrought aluminum works : a) Supply & install wrought iron main gate c/w key lock 18 Painting works (5 colour at Wash & Wear include white) : a) Apply Nippon / ICI emulsion painting for whole house wall and ceiling. b) Apply Nippon / ICI paint to painting for all doors, door frames & expose piping 19 General service a) To alter main iron gate and bedroom doors when construct the cement mortar base. b) Provide acid/ chemical washing for whole house after the progress of renovation c) Haulage for heavy construction material to job site d) Labour to clear and remove all heavy construction debris at job site. e) Permit fee Total : $27900 Any comments from anyone please? Edited July 23, 2008 by typhoonz Share this post Link to post Share on other sites
ace_mav 0 Report post Posted July 23, 2008 Here's a description of my quotation. My house area is 103 sqm (4A) 1 Specialized Work : a) Provide consultation on design concept & services by designers b) Provide consultation on selection & usage of materials by Designers c) Provide consultation on selection of lighting, accessories & furnishing materials by Designers d) Provide site co-ordination during the process of renovation work 2 Demolishing works **** hall /Dinning hall /Bedroom area /Balcony : a) Demolish existing 3nos doors b) Demolish existing main gate c) Demolish existing living hall & 3 room's windows and grilles d) Demolish existing cornice **** hall e) Demolish existing arch at kitchen entrance f) Dismantle existing divider **** hall g) Demolish existing cornice at 3 bedrooms h) Dismantle existing wardrobe at master bedroom I) Dismantle existing laminate flooring at master bedroom j) Dismantle existing wardrobe at bedroom 2 k) Dismantle existing carpet at bedroom 2 l) Dismantle existing wardrobe at bedroom 3 3 Carpentry works at Master bedroom : a) Supply & install 8ft design sliding wardrobe with laminate finish 4 Carpentry works at bedroom 3 : a) Supply & install 6ft design wardrobe with laminate finish 5 Demolishing works at Kitchen area : a) Dismantle lower kitchen cabinet b) Dismantle upper kitchen cabinet c) Hack off kitchen existing cement sink support d) Hack off kitchen existing cement cooking support e) Hack off kitchen existing wall tiles f) Hack off kitchen existing floor tiles and cement mortar g) Hack off kitchen existing 50mm cement base h) Chipping kitchen top existing wall I) Remove existing rubbish chute 6 Construction wet works and plumbing works at Kitchen area : a) Supply & apply 104 quick seal flexible chemical cementitious to waterproof flooring to prevent water leakage b) Supply & lay country ceramic tiles for kitchen flooring c) Construct of 50mm cement mortar washing machine base with country tiles finishing at kitchen area d) Supply & install PVC drainage piping for kitchen sink and washing machine with gully floor trap e) Construct of 50mm cement mortar fridge base with country tiles finishing f) Construct of 50mm kitchen cabinet cement mortar base with country tiles skirting finishing g) Supply & install new aluminum rubbish chute (flat type) h) Construct low wall using H/B with country tiles finishing i) Wall washing /Cement tamping /Chemical cement plastering /Cement plastering and leveling kitchen wall and patch up smooth j) Supply & lay wall tiles(9ft X 3ft) in between top and bottom kitchen cabinet k) Supply & lay (heavy duty) Ceramic skirting at kitchen area l) Supply & install stainless steel piping for kitchen sink and washing machine (All water inlet c/w stop-cock) m) Provide labour to install sink & tap 7 Carpentry works at Kitchen area(24ft) : a) Supply & install 1 no. of L-shape bottom cabinet with laminated surface and ABS trimming finish include hinges b) Supply & install 1ft(L) full height tall cabinet to box up PVC sewage pipe with laminated material and ABS trimming finishing c) Supply & install 1 no. of top cabinet with laminated surface and ABS trimming finish include hinges d) Supply & Install 1 set of lower cabinet drawer in laminated surface finish e) Supply & install 1 no. of cutlery tray f) Provide labour to install cooker & hob 8 Supply & Install 01 no. of stainless steel dish tray 9 Supply & Install 01 no. of 13ft solid surface work top 10 Demolishing works at Common toilet : a) Hack off existing wall tiles and cement screed b) Hack off existing floor tiles and cement mortar c) Chipping top existing wall d) Remove existing WC e) Remove existing toilet door 11 Construction wet works and plumbing works at Common toilet : a) Supply & apply 104 quick seal flexible chemical cementitious to waterproof flooring to prevent water leakage b) Supply & lay country tiles for toilet flooring c) Cement tamping / chemical cement plastering and leveling toilet top wall before lay wall tiles d) Supply & lay wall tiles at toilet wall up to ceiling height e) Provide labour to install toilet WC (squatting to sitting) f) Provide labour to install toilet basin g) Provide labour to install toilet accessories h) Provide labour to install storage heater i) Supply & install new hot & cold stainless steel piping j) Construct main kerb include grinding edge finishes 12 Demolishing works at Master toilet : a) Hack off existing wall tiles and cement screed b) Hack off existing floor tiles and cement mortar c) Chipping top existing wall d) Remove existing WC and basin e) Remove existing toilet door 13 Construction wet works and plumbing works at Master toilet : a) Supply & apply 104 quick seal flexible chemical cementitious to waterproof flooring to prevent water leakage b) Supply & lay country tiles for toilet flooring c) Cement tamping / chemical cement plastering and leveling toilet top wall before lay wall tiles d) Supply & lay wall tiles at toilet wall up to ceiling height e) Provide labour to install toilet WC and basin f) Provide labour to install toilet accessories g) Supply & install new hot & cold stainless steel piping h) Construct main kerb include grinding edge finishes 14 Cornices/False Ceiling works : a) Supply & install false ceiling **** hall b) Supply & install false ceiling at kitchen passage way c) Supply & install false ceiling at bedroom passage way d) Supply & install false ceiling at master bedroom e) Supply & install L-Box at bedroom f) Supply & install false ceiling at bedroom g) Supply and plaster kitchen existing ceiling to smooth finish 15 Aluminum works (white powder coated colour frame c/w normal glass) : a) Supply & install 1no of adjustable louver windows (frosted glass) at common toilet(4ft X2ft) b) Supply & install 1no of adjustable louver windows (frosted glass) at master toilet(4ft X2ft) c) Supply & install sliding windows at kitchen d) Supply & install 1set of sliding windows **** hall e) Supply & install casement windows at master bedroom f) Supply & install 1set of sliding windows at bedroom 2 g) Supply & install casement windows at bedroom 3 h) Supply and install aluminum grilles at kitchen i) Supply and install aluminum grilles **** hall j) Supply and install aluminum grilles at master bedroom k) Supply and install aluminum grilles at bedroom 2 l) Supply and install aluminum grilles at bedroom 3 m) Supply & install 01 set of powder coated aluminum bi-folding door at common toilet n) Supply & install 01 set of powder coated aluminum bi-folding door at master toilet 16 Wooden doors : a) Supply & install 01no.of nyatoh door c/w key lock for store room b) Supply & install 03nos.of nyatoh door c/w key lock for bedrooms 17 Wrought aluminum works : a) Supply & install wrought iron main gate c/w key lock 18 Painting works (5 colour at Wash & Wear include white) : a) Apply Nippon / ICI emulsion painting for whole house wall and ceiling. b) Apply Nippon / ICI paint to painting for all doors, door frames & expose piping 19 General service a) To alter main iron gate and bedroom doors when construct the cement mortar base. b) Provide acid/ chemical washing for whole house after the progress of renovation c) Haulage for heavy construction material to job site d) Labour to clear and remove all heavy construction debris at job site. e) Permit fee Total : $27900 Any comments from anyone please? Interestingly very cheap though I would suggest get an itemised quote from them and compare it with some quotes you get in this forum. Sometime if its too good to be true..it probably is..hehe.. Share this post Link to post Share on other sites
typhoonz 0 Report post Posted July 23, 2008 Interestingly very cheap though I would suggest get an itemised quote from them and compare it with some quotes you get in this forum. Sometime if its too good to be true..it probably is..hehe.. I'm not sure of the market price so was thinking that it's a bit expensive. Share this post Link to post Share on other sites
ace_mav 0 Report post Posted July 23, 2008 I'm not sure of the market price so was thinking that it's a bit expensive. if you asked me..its very fishy...you can try ask everyone here and I believe they will say the same...especially those who owned T-Blogs...i am sure ppl will agree with me.. judging by the works and material..it should be around 50-60k for a normal ID..even a contractor won't be this cheap...probably 5-10k lesser.. so all the best in your findings! Share this post Link to post Share on other sites
shearer9 0 Report post Posted July 24, 2008 if you asked me..its very fishy...you can try ask everyone here and I believe they will say the same...especially those who owned T-Blogs...i am sure ppl will agree with me.. judging by the works and material..it should be around 50-60k for a normal ID..even a contractor won't be this cheap...probably 5-10k lesser.. so all the best in your findings! I agree. It's really cheap and will advice you to request for the itemised quote. Check for hidden costs. Also check what is the price of tiles psf they are quoting here. $2psf or 3psf? When you go to the shop to choose tiles, you may be restricted to only the $2psf tiles and if you want the nicer tiles, you may have to top up for it. As all these are the hidden costs. So go through every item with the ID on the possible extra costs you may have to fork out. Share this post Link to post Share on other sites
aves 0 Report post Posted July 24, 2008 ya get itemized quote. else very hard to judge Share this post Link to post Share on other sites
spidey 0 Report post Posted July 24, 2008 ya get itemized quote. else very hard to judge same here, i agree, get an itemized quote then get from 2 or 3 other ID and compare. Share this post Link to post Share on other sites
typhoonz 0 Report post Posted July 24, 2008 A big thank you to all who have replied... I'll meet up with him and get an itemised quote like what everyone has suggested. Share this post Link to post Share on other sites
Jester28 1 Report post Posted July 24, 2008 A big thank you to all who have replied... I'll meet up with him and get an itemised quote like what everyone has suggested. there is no tiling works for the living and bedrooms? which contractor or ID.. i oso need to find a quote as cheap as yours. .. can pm me? Share this post Link to post Share on other sites
happywheel 0 Report post Posted July 24, 2008 I agree. It's really cheap and will advice you to request for the itemised quote. Check for hidden costs. Also check what is the price of tiles psf they are quoting here. $2psf or 3psf? When you go to the shop to choose tiles, you may be restricted to only the $2psf tiles and if you want the nicer tiles, you may have to top up for it. As all these are the hidden costs. So go through every item with the ID on the possible extra costs you may have to fork out. Hi bro may i know where u buy the LCD TV...me on low budget cheers Share this post Link to post Share on other sites
typhoonz 0 Report post Posted July 24, 2008 there is no tiling works for the living and bedrooms? which contractor or ID.. i oso need to find a quote as cheap as yours. .. can pm me? My flooring for the living room will be the original marble but need to get it polished after everything... I'm getting Kronotex laminated flooring for the bedrooms... Got it straight from Kronotex and not through the ID... Share this post Link to post Share on other sites
carboonxy 0 Report post Posted July 25, 2008 Hi. May I know which contractor you got the quote from? I'm currently looking for a contractor to renovate my new place too. Have not come across one with such a good rate, though. Share this post Link to post Share on other sites
typhoonz 0 Report post Posted July 25, 2008 Hi. May I know which contractor you got the quote from? I'm currently looking for a contractor to renovate my new place too. Have not come across one with such a good rate, though. I'm still pending his drawings and itemised quote... Share this post Link to post Share on other sites
