jopp
Digital Door Lock
The shipping cost is very cheap, so order 3 in separate transaction to avoid GST.
I've been using Samsung Ezon for the past 3 years, also bought from eBay as well. Installed by myself and no problem at all.
This relatively cheap product, I don't think warranty is necessary. Just buy a new one if spoilt
Wow! You must have equipped with all the handy equipment. Think it's kinda challenging to self install.
However, I am more afraid that if done wrongly, it might spoil the lock.
I don't think it's quite necessary to have all handy equipment.
Can use back the hole from the old lock. I did mine using a screwdriver and those screw provided only.
If you didn't align it properly, it won't spoil the lock. Only it won't lock.
However if you want to buy those with handle then it would be more challenging cos it requires 2 precise holes on the door.
So my suggestion if you want to DIY, buy the lock only and use existing handle.
Edited by vhardono
Upgraded from SHS-5120 to a fingerprint SHS-5230 :sport-smiley-004: (kids more happy though I like RFID card more).
Moved the old SHS-5120 to a rental unit (tenant very happy).
All happy. :drunk:
Rover, we are running special promo for any installation this weekend. Please call us 98307788.
... and the person that sold the digital lock to you is equally happy as well.
Everyone happy :D
All happy. :drunk:
Edited by Recnamor
The problem with the lock is not fingerprint recognition but the door alightment
I have check out your my digital lock wesbite, you provide door alightment service?
I have contact interlock and adjust the alightment however the problem still arise, any help?
I believe is the door frame hole not aligned to the door lock.
Taking picture would help others to see your problem more clearly.
Edited by sohnice
was thinking of buying the traditional ones to replace the current one. saw pretty good deals at Home Fix (not all outlets have) but variety ain't there... Yale digital ones i saw range from $500 to $1388. how much are yours?
For normal yale single grip lock with installation will cost $250. However, the size of the new lock set will not 100% cover after the replacement due to the difference in size
You may consider to change to digital lock to experience keyless entry.
The YDR 1212 cost $588 with installation and replace your existing lock
http://mydigitallock.com.sg/yale-ydr-1212-digital-lock-replace-single-grip-lock-for-hdb-perfectly/
Edited by mydigitallock
Still evaluating whether to get a digital lock.
Questions
1. Model that can choose btw key, findgerprints and passcode? Comes with alarm?
2. Since electronic ie wires short-circuit etc if doesn't work how?
3. What if no battery?
4. Post sales support stability?
Questions
All the Samsung, Yale or gateman digital locks operates by AA batteries. If the battery runs out, you may use the key to overwrite the system or use a 9v battery to charge
For locks that is warranty by the local distributor, it comes along with the warranty card and after sales service provide by the dealer
A fingerprint lock would be ideal
