briansg
Inverter System & Non Inverter System
Hi I'm in the mist to decide whether to install a Inverter System and Non Inverter System , Any advise on this issue ?
- Any Major different in SP Bills ???
- How much different in $$$???
Depends on how much you use your Aircon.
I was pondering over this last time too. In the end, I got a non inverter air con as my wife didnt like air con and we will not use it that often.
Most importantly, get ozone free refrigerant!!!
ya, invertor only helps u save electricity if your usage is high, e.g several systems ON at the same time for a period of time. Or a certain unit always full blasting large space (e.g living room). Then u need invertor.
If u are occasional user, once in a while only ON 1 unit, then non-invertor is enough. Coz u can't harvest the benefits of invertor.
