Atrina-er
Opinions On Quote For New 4 Rm Flat
Hi, I've juz got tis quote from an ID firm for my 4 RM Prenium flat ( 90 sqm ).
Is it reasonable???
Miscellaneous Works
1. Painting all internal wall & ceiling using NIPPON/ICI - $1200
2. Supply & lay floor protection for 03 x bedrooms - $90
3. provide acid washing for whole unit tiled area - $150
4. General washing of whole unit upon handover - $60
5. Supply & install aluminum window grilles for Service Yard - $180
6. Supply & install sandblasted top hung sliding dr for - $890
kitchen entrance
Ceiling works
1. Supply & install L Box est 60ft length for living room - $360
2. Supply & install L Box est 50ft length for MBR - $300
3. Supply & install est 40sqft False Ceiling for Foyer area - $100
4. Supply & install est 60sqft FAlse Ceiling for MBR - $150
Plumbing Works
1. Supply & install new stainless steel/copper piping for - $550
kitchen & 02 x WC
2. To connect inlet/outlet point for 02 x basin - $60
3. To connect inlet/outlet point for sink - $30
4. To connect inlet/outlet point for washing machine - $30
Carpentry Works
1. Fabricate & install 6 1/2ft length feature wall for - $1200
Bomb Shelter
2. Design & construct 20ft kitchen cabinet with solid top - $2100
Total - $7450
Additional
1. Supply & lay lighting wiring point with casing per point - $30
2. Supply labour to install lighting per point - $8
3. Supply & lay single socket power point with - $45
casing per point
4. Supply & lay double power point with - $60
casing per point
5. Supply & lay heater point with casing per point - $100
6. Supply & lay Air con point with casing per point - $100
* GST waived.
i think a bit high, why u not enggage contractor?its more cheaper
eg: acid washing for whole house 2times , mine only $120, and ur id charge u $210 already :)
"3. provide acid washing for whole unit tiled area - $150
4. General washing of whole unit upon handover - $60"
Miscellaneous Works
5 colors/unlimited?
should be lay for whole hse, sometimes floor protection can be FOC , depending on ur ID, otherwise, shouldnt cost more than $180
acid washing is needed only if home owners got do flooring. 2 companies say if flooring is already done by HDB, wash 2 or 3 times the usual way can liao, no need acid wash also can
btw, parquet floor cannot touch water, u know
price is okay, r u getting double hollow, silver aluminium?, if u r not doing window pane, u may have to do powder-coated alumium grilles (u gotta check w HDB), and u MUST stick to te 3 types of approved grille-designs by HDB
kitchen entrance
seems a bit ex, got a quote for 1 fix door size tempered glass panel + 1 sliding clear tempered glass door $900
Ceiling works
read more on false ceiling here www.renotalk.com/forum/index.php?showtopic=12738
Plumbing Works
1. Supply & install new stainless steel/copper piping for kitchen & 02 x WC - $550
heard that altho stainless steel is more ex, but it may give u trouble if it is installed by a not-so-skilful guy, coz it is more difficult to bend than copper (wat is WC?)
if basin is alr installed by HDB still need to connect the inlet/outlet ???
this one very simple. can diy. if they wanna do for u, should be FOC
Carpentry Works
1. Fabricate & install 6 1/2ft length feature wall for Bomb Shelter - $1200
hw come so ex? got wat kind of special design on it? if it is plain and only matt/gloss laminate finish, can get it at $550 for 6 ft
price is okay, rember to get the solid top w back splash and ask for 3 free glass cabinets and free stainless steel dish rack and matching culinary tray
Additional
1. Supply & lay lighting wiring point with casing per point - $30 ok
2. Supply labour to install lighting per point - $8 ok
3. Supply & lay single socket power point with casing per point - $45 wat this
4. Supply & lay double power point with casing per point - $60 wat this
5. Supply & lay heater point with casing per point - $100 wat this? installation of storage tank/water heater for both toilets can be FOC, depending on ur ID
6. Supply & lay Air con point with casing per point - $100 wat this? they give u free aircon?
* GST waived (80% ID i approached will waive...)
btw, u not doing any carpentary for ur bedrooms and living rm?
Edited by mud3210
Hi ,
I jus finish renovating my condo n my contractor is nice n reliable. If u all wan,u can pm me for his contact. His carpentry workmanship is v good.
cheers.
Hi , I jus finish renovating my condo n my contractor is nice n reliable. If u all wan, u can pm me for his contact. His carpentry workmanship is v good.
like hw very good? can i knw wat do u look out for in the carpentary which u said is very good? u wan to post the company name and contact person here so we can search for more info on them, thanks.
