Triple 7 0 Report post Posted April 14, 2009 Hi, For the water heater, is it true that when adjust too much cold water it will shut off the gas? and to restart it, you need to run out to the installed unit to make adjustment to the setting? Share this post Link to post Share on other sites
millienium_bear 0 Report post Posted April 15, 2009 Hi, For the water heater, is it true that when adjust too much cold water it will shut off the gas? and to restart it, you need to run out to the installed unit to make adjustment to the setting? not really.. the city water heater operated on battery and need 2 pipes to run water.. 1 pipe is to let in cold water into water heater to let out hot water from another pipe.. u can read more info : http://www.citygas.com.sg/waterheater/index.htm for my side, no problem so far... Share this post Link to post Share on other sites
ema82 0 Report post Posted April 24, 2009 My kitchen is super tiny and now, the place on top of my washing machine don't have enough width to put gas dryer . That's only space for me to put the dryer . So can we let the dryer cover abit of the window or put on the floor? Share this post Link to post Share on other sites
Mimi 0 Report post Posted May 16, 2009 My kitchen is super tiny and now, the place on top of my washing machine don't have enough width to put gas dryer . That's only space for me to put the dryer . So can we let the dryer cover abit of the window or put on the floor? Hi i am considering to buy a dryer cum washer untill i saw this thread What is the difference between electric dryer like LG and this city gas? How do they work? Thank you Share this post Link to post Share on other sites
millienium_bear 0 Report post Posted May 20, 2009 My kitchen is super tiny and now, the place on top of my washing machine don't have enough width to put gas dryer . That's only space for me to put the dryer . So can we let the dryer cover abit of the window or put on the floor? its not wise to place the dryer on the floor cuz it might not be good for ur back and hot air will let out. but i think its ok to over a bit of the window cuz the dryer needs a well ventilation area to let out hot air. Share this post Link to post Share on other sites
millienium_bear 0 Report post Posted May 20, 2009 Hi i am considering to buy a dryer cum washer untill i saw this thread What is the difference between electric dryer like LG and this city gas? How do they work? Thank you i prefer citygas dryer cuz it helps to save about 20-30% of time & money in long run. u can read up on how it works. ->http://www.citygas.com.sg/gasdryer/index.htm i have not used electric dryer like LG before, so i cannot give u comments. take your time to choose and compare a electric applicance for ur home. Share this post Link to post Share on other sites
m3lwan 0 Report post Posted May 20, 2009 Hi All, Just to check, will the dryer be working like your stove cooking the clothes to dry them up? If its the above scenario, won't it be dangerous to leave the fire on while you are sleeping or away? Share this post Link to post Share on other sites
millienium_bear 0 Report post Posted May 21, 2009 Hey, I have no idea about it, because my kitchen is too small.. maybe considering the electric washer cum dryer machine... wont take up much space.. but disadvantage is that the electric bill will be 20-40% higher than the citygas dryer.. Share this post Link to post Share on other sites
millienium_bear 0 Report post Posted May 21, 2009 Hi All, Just to check, will the dryer be working like your stove cooking the clothes to dry them up? If its the above scenario, won't it be dangerous to leave the fire on while you are sleeping or away? no, it does not happen to me.. a few times, i leave the dryer to complete the process while i am away for a short while.. it will give out beep when finished and the button changes from 'Operation' to 'Finish'.. Share this post Link to post Share on other sites
simpleveity 0 Report post Posted May 21, 2009 hi all citygas dryer users! anyone can roughly tell me how much your monthly bill comes up to with the dryer? Share this post Link to post Share on other sites
millienium_bear 0 Report post Posted May 21, 2009 hi all citygas dryer users! anyone can roughly tell me how much your monthly bill comes up to with the dryer? my bill varies cuz of my aircon usage for my 4rm home.. roughly $50-100 monthly.. for my gas bill, roughly $5-8 cuz i use the dryer 2 times per week and dun cook much.. Share this post Link to post Share on other sites
streamrsz 0 Report post Posted May 21, 2009 I intend to convert my washroom 3 into a washing machine and dryer room. The citygas technical came by and mentioned that likely the dryer will not be approved to put in there thus I've got to scrap the idea of having Citygas dryer Share this post Link to post Share on other sites
simpleveity 0 Report post Posted May 22, 2009 hi millenium_bear seems affordable , we'll be using alot of the aircon in the future too, thanks! Share this post Link to post Share on other sites
millienium_bear 0 Report post Posted May 22, 2009 hi millenium_bear seems affordable , we'll be using alot of the aircon in the future too, thanks! i using aircon inverter type... not sure how much the bill comes up if using non-inverter type... Share this post Link to post Share on other sites
simpleveity 0 Report post Posted May 22, 2009 i using aircon inverter type... not sure how much the bill comes up if using non-inverter type... oh ok, so which model aircon are you using? Share this post Link to post Share on other sites
