big orange
Help Me See Quotation For My Bedok Brand New Hdb Unit
A Professional Services
1 Design & site co-ordination
2 Space planning layout plan
3 Perspective drawings on all carpentry works
4 Warranty of workmanship & after sales services for 5 years
5 Arrangement for PUB gas pipe installation
6 Consultation on selection of lights, furnitures & accessories
B Masonry Works ( max. tiles rate S$2.50 per sqft )
1 Supply & lay Spain or Italy ceramic floor tiles @ living, dining & household shelter c/w
cement screeding & skirting
2 Supply & lay German Technology laminated flooring @ 03 bedroom c/w warranty,
cement screeding & skirting (**Valids for some units only)
3 Supply & lay German Technology laminated flooring @ studyroom c/w warranty,
4 Supply & lay heavy duty ceramic floor tiles @ kitchen c/w cement screeding & waterproofing
5 Supply & construct base for kitchen cabinet, fridge & washing machine with matching floor tiles
6 Supply & construct shower kerb @ both bathrooms
7 Haulage loading of sand, cement & materials to unit
C Plumbing Works
1 Connect inlet & outlet piping for kitchen sink & washing machine
2 Supply labour to install storage heater or 02 nos. of instant heaters
3 Supply labour to install accessories @ both bathrooms
4 Supply labour to install kitchen sink, hob & hood
D Ceiling Works
1 Supply & install false ceiling or light box @ living & dining
2 Supply & install false ceiling @ foyer & passageway
E Painting Works
1 Supply & apply 03 coats of ICI Dulux pentalite paint to all internal walls & ceilings
( max. 8 colours )
2 Supply & apply ICI gloss paint to all water piping, gates,doors, door frames & sewage pipe
F Miscellaneous
1 Supply & lay protection sheet
2 Clean up whole unit with chemical
3 Clearing off debris
G Custom Made Build-in Furniture
Kitchen Area
1 Design & fabricate top & bottom kitchen cabinet in laminate finish c/w 04 sides ABS trimming
swing doors, cuttlery tray, 02 pcs of glass panels & designer handles ( max. 24ft L )
( Laminates from Duropal of Germany or Lamicolour of Italy )
2 Supply & install stainless steel dish rack with hydralic lift-up 04 sides ABS trimming door &
glass panel ( max.3ft L )
H Free Item
1 Free solid surface worktop 12ft L worth S$1200.00
I Optional Items (Max. tiles rate S$2.80 per sqft)
1 Upgrade flooring @ living, dining & household shelter to ( 600x600mm ) polished
homogeneous floor tiles
2 Upgrade flooring @ 3 bedrooms to ( 600x600mm ) polished homogeneous floor tiles
3 Upgrade flooring @ studyroom to ( 600x600mm ) polished homogeneous floor tiles
4 Upgrade flooring @ kitchen to ( 300x300mm ) homogeneous floor tiles
Additional Works
I Glass Works
1 Supply & install 10mm thick clear tempered glass swing door @ kitchen entrance ( appx.3ft L )
J Custom Made Build-in Furniture - All laminates from Germany or Italy with solid ply wood
Living & Dining Area
1 Design & fabricate full height shoe cabinet in laminate finish ( appx.4ft L )
2 Design & fabricate feature wall @ Tv area in laminate finish c/w glass or mirror
design & stainless steel trimming ( appx.6ft L )
3 Design & fabricate suspended Tv console in laminate finish c/w glass panels ( appx.6ft L )
Master Bedroom Area
4 Design & fabricate full height wardrobe in laminate finish c/w swing doors ( appx.6ft L )
5 Design & fabricate dresser table in laminate finish c/w mirror ( appx.3ft L )
total around 18.5K.
Comments pls.
C Plumbing Works
D Ceiling Works
E Painting Works
( max. 8 colours )
F Miscellaneous
Kitchen Area
H Free Item
Additional Works
I Glass Works
Master Bedroom Area
total around 18.5K.
Comments pls.
You need to get a detailes breakdown. Its more advantageous to you and we can see clearer what the different prices are on the quote.
:notti:
l think it ur sig :deal:
lol..no wonder..i was thinking of it also
btw that (max. tiles rate S$2.50 per sqft), you can try to negotiate it up to $3.00 per sqft
Some comments:
1) u sure u wanna do ceramic tiles? Homo tiles is the in thing now. Saw an upgrade package.
2) cement screeding u can actually ask HDB do it for you for free, if u wanna do parquet, when collecting keys.
3) Kitchen, toilet and Bomb shelter are already tiled.
4) 10mm = 1cm glass door is very heavy, u sure? It's like opening bank door. Also doing swing, I doubt that place has enough allowance, will hit the bomb shelter door.
Ya, better to have a proper breakdown rather than a 1 lump sum.
C Plumbing Works
D Ceiling Works
E Painting Works
( max. 8 colours )
F Miscellaneous
Kitchen Area
H Free Item
Additional Works
I Glass Works
Master Bedroom Area
total around 18.5K.
Comments pls.
Are u getting your new flat at bedok central? :rolleyes:
