bassy 0 Report post Posted May 1, 2008 Compliant to TC they told me the pressure is low for high floor mine is 9th floor and i have change to copper pipes. So shd i go to HDB or PUB to compliant? Share this post Link to post Share on other sites
yokine9a 1 Report post Posted May 1, 2008 Both of them won't or can't help you. You just have to live with it. One way is to buy a "stop cord", this should be able to help a bit. I learned this from my contractor who did the reno work for my house. I am living in the 10th floor. Share this post Link to post Share on other sites
Starscream 0 Report post Posted May 1, 2008 Yokine: What is this "stop cord"? and is it true for all high floors to have water pressure issues? Will the double-flow from a storage heater tank solve the problem somewhat? yokine9a said: Both of them won't or can't help you. You just have to live with it. One way is to buy a "stop cord", this should be able to help a bit. I learned this from my contractor who did the reno work for my house. I am living in the 10th floor. Share this post Link to post Share on other sites
bassy 0 Report post Posted May 1, 2008 I think they can solve the issue it whether they want to do it. My previous hse use to be low pressure after they change the outside water pipe the pressure quite strong Share this post Link to post Share on other sites
Kris Ng 0 Report post Posted May 1, 2008 Hi guys, so this pressure problem is actually hdb or tc problem? Share this post Link to post Share on other sites
yokine9a 1 Report post Posted May 2, 2008 It is a water tap that connects directly to your heater. When I was in the shop that sells bathroom accessories, I just mentioned "stop cord" and the sale girl knew what I wanted. Yes, not sure about newer flats, but all old flats have this water pressure issue cos higher units are closer to the water tank at roof top. Don't know what double-flow is, can't answer your qtn Pressure problem is HDB problem. Sometimes, it is not the water pipe that is causing the problem, it is the shower head that connect to your water outlet. Their pipe might be too small or too thick that slow down the water flow. One of my tap in the bathroom was flowing alright until I put in a PUB water saving rubber ring (forgot its name, got it free from PUB), the water flow immediately slowed down. In the end, I removed the rubber ring. Also, the water how the water pipe runs in your flat can make a difference. It should be closed to the same level as your water tap. Share this post Link to post Share on other sites
Starscream 0 Report post Posted May 2, 2008 Thanks Yokine. By double-flow I meant the combine rush of hot/cold water from two pipes due to the installation of a storage heater tank may increase the throughput. I think the rubber ring is called a thimble? Yes agree that running it at the height which the water tap is located would be good. Share this post Link to post Share on other sites
bassy 0 Report post Posted May 2, 2008 The problem now is my whole hse pressure low Share this post Link to post Share on other sites
