tofler
Windows [sliding Or Cascading]
Dear all,
My service balcony was supposed to be installed with a cascading windows, but my ID installed the sliding one 8| , so could anyone advise me which is better and which one is more costlier? So i could get a refund from them... :deal:
Thank you so much...
Edited by tofler
Cascading one is more expensive. HDB has higher requirements for installing cascading windows cos many cases of such window piece dropped off and fell onto ground. Sliding one is easier to install but eat up space, cos one track for each glass slide.
Which is better depends on individual preference. I prefer cascading one cos I can open them fully and have more sunlights coming in. But when it rains, then sliding one is better cos you can still keep your windows open but cascading one cannot. You have to close it else the screws on your windows will get rusty 8|
So you should get a refund from them :deal:
Cascading is harder to clean compare to sliding windows.
but if rain, I will still close the window else the rain will wet my home.
And lastly, it really depends on individual perference.
Which is better depends on individual preference. I prefer cascading one cos I can open them fully and have more sunlights coming in. But when it rains, then sliding one is better cos you can still keep your windows open but cascading one cannot. You have to close it else the screws on your windows will get rusty :notti:
So you should get a refund from them :jawdrop:
Heh... Thanks Yokine9a.
That's the kind of confirmation that i need. :bangwall:
Thanks Raincole,
Yes, i also understand that sliding one are harder to maintain becos of all the grooves.
But my M-in-Law, also mentioned that if use cascade one is difficult to hang clothes outside, as ours are those "slim" 3 windows kind... :jawdrop:
So kinda stuck in dilemma... whether to ask for compensation or get them to replace it as stipulated in contract.
Never heard of cascading windows, if possible can someone post pictures of cascading windows?
The only factor I considered when deciding to install sliding or casement windows was which type offers better seal against dust and draught. My previous apartment had sliding windows and doors, and the place gets so dusty even when the windows are shut. Nowadays the air in Singapore is so dusty with very fine dust!
So I installed casement windows, replacing even the lourve windows in my bathroom and toilet.
Luckily my ID's window fabricator did an excellent job: the casement windows were lined with rubber and some kind of "brush" material along the edges. When the windows are shut, no dust or draught could get inside the flat. If I open the windows my flat gets dusty within minutes, as my place is quite windy most of the time.
Keeping out the draught means yr aircon operates better and uses less electricity. :yamseng:
I think he/she means CASEMENT window.
Some newer HDB has the stainless steel poles outside the service balcany that you cannot do casement, can only do sliding. Coz casement when u open, it will hit the poles.
Casement:
- better sound isolation
- harder to clean
Sliding:
- min 1 panel will be wasted.
the IN thing now is slider-casement. Newer HDB comes fitted with those.
there are 'cascading' windows
it's something like the top hung we have but it's all the way
so instead of opening like casement (pushing open to the side), cascading ones push open towards the top
good for days when it's raining
but i'm not sure which type TS is referring to
some newer flats have these windows installed :yamseng:
thanks, applefreak. sounds like my toilet window is like that -- to open, push and it will open out towards the top, except my aluminum guy called that type 'top-hung' casement window when they applied to the hdb for approval.
some old houses have windows that are opened by pushing / pulling up or sliding the window pane vertically, sort of like a normal sliding window except the panel moves up and down. thot this was the 'cascading' type referred to? :unsure:
Edited by BlueFly
yes..I was told they are top-hung casement too.
But I was also told that not all hdb flats allowed to install this for the toilets. It seems that it will depend on how your external wall structure/surface outside the toilets was built. Heard this mumbo jumbo but I didn't quite understand :dunno:
I like your windows. The window fabricators I spoke too doesn't provide this felt strip thing. I find this very cool as it makes sure that there will be no window gaps :good: . Can PM me your window contact? Thanks !
:yamseng:
it's called top-hung casement when it's just a small part above a casement window
i.e. the push up and out part is above the normal casement window
there's some new flat with 3 panels of push-out-and-up i.e. totally no casement window
not sure what it's called :P
..snip..
:yamseng:
Thanks, kunning. Unfortunately I don't hv the fabricator contact as they worked for my ID.
Will however try to get the contact from the ID and pass it to you via pm.
rgds
