leongheng70
Sharp Corners
Hi i just view a 5rm flat at sembawang, in total i like that place but there are a problem that i need yr advise.
you see each of the three bedrooms, there are a 160 degrees angle at the end of each bedroom, therefore shall i purchase the flat or is it harmful.
finding a squarish house with squarish bedrooms/kitchen/livingroom is tough.
finding the above one with all it's facing/sitting that suits you is worse....took me close to 2 yrs!:yamseng:!
but then i am happily living in such a house now :good:
finding the above one with all it's facing/sitting that suits you is worse....took me close to 2 yrs!:P!
but then i am happily living in such a house now :dancingqueen:
Hey can i have the list of feng shui master that you had ? :P
Hey can i have the list of feng shui master that you had ? :)
Just completed my blueprint of the house that i wanted to buy, please take a look at it and comment if this is worth it. If you noticed the 3 bedrooms have some sort of angle, is a strict no no or is there anything that can be done.
http://www.floorplanner.com/dmt6fd/Floor+plan/503B+
Do advised...
Thanks
Andy
According to my FS master, the outside is more important than the inside. Stuff like, got sharp roofs of adjacent buldings pointing at your flat? Mountains, hills, rivers in good position relative to your flat? Got cemetary, temple, church near your flat? All these are much more important than the inside of the flat. Fyi, I just purchased a house of which the interior is like negative image of yours. You know, like reversed, or mirror-image. Lot of sharp edges and corners. But it was right for me, so I buy it without hesitation.
Good. At least, your FSM knows the fundamentals in FS. :thumbs up:
To have good external FS is 70% of the job done in FS. Of cos, if internal FS is not as good - meaning irregualr shape, sharp corners etc, the ther 30% is gona score less points. But compare to others who have bad external, all you have to do is to bring Qi in, use the right sector and do the right things on good dates. Then when you make more money, move to a new place where you get both external and internal right.
Internal FS has to do much with immediate family relations. If you have other members of yr family staying with you just be more patient and KNOW the limitation of this residence.
