SmartFool
Our Humble Abode
My quote today
very sian
cos very ex esp the electrical
PART A - GENERAL WORK
1) HACKING AND HAULAGES Price S$
Supply labour and equipment to :~
1.1 Remove existing laminate flooring to Whole house. LS $650.00
1.2 Hack floor tiles to Living & Dining. LS $400.00
1.3 Hack wall & floor tiles to Kitchen. LS $750.00
1.4 Hack floor tiles and skirting to Private Garden's Terrace. LS $200.00
1.5 Hack floor- and wall tiles to Master and Common Bathrooms. 2unit $900.00
1.6 Hack floor tiles and skirting to Roof Garden. LS $400.00
1.7 Hack floor tiles and skirting to Master and Bedroom 2's Balcony. LS $200.00
1.8 Dismantle existing build in wall feature and TV console ****. LS $250.00
1.9 Dismantle existing Kitchen cabinets and Island unit. LS $250.00
1.10 Dismantle existing built-in wall feature at Master Bedroom. LS $180.00
1.11 Dismantle existing built-in walk-in wardrobe at Master Bedroom/2. LS $350.00
1.12 Dismantle existing built-in wardrobe at Bedroom 4. LS $180.00
1.13 Dismantle existing bathtub, toilet bowl, vanity cabinets and shower screen at all Bathrooms. LS $300.00
1.14 Haulages for loading of materials and clearing of debris and hardcore off-site. LS $800.00
2) MASONRY AND TILING WORKS
Living, Dining, Kitchen
2.1 Supply and install 600 x 600mm homogeneous floor tiles to Living, Dining & Dry Kitchen. $2,500.00
2.2 Supply and install 300 x 600mm homogeneous floor tiles to Wet Kitchen. $700.00
2.3 Supply and install ceramic/homogeneous wall tiles to exposed surfaces at Wet Kitchen. $1,200.00
2.4 To plaster cement & sand with skim coat smooth finishing to Dry Kitchen. $900.00
2.5 Supply and construct concrete Kitchen cabinet base with tiles trimming. ('L' shape) $350.00
2.6 Supply and install concrete fridge base with tiles finished. $100.00
2.7 Supply and install concrete washing machine base with tiles finish. $100.00
2.8 Supply and install 300 x 600mm homogenous floor tiles with skirting to Private Garden 's Terrace. $1,000.00
2.9 Supply and apply waterproofing membrane to Kitchen and Terrace. $300.00
3) Bathroom 1 ( 2nd Storey Master Bedroom )
3.1 Supply and install 300 x 300mm homogeneous floor tiles. $450.00
3.2 Supply and install ceramic/homogeneous wall tiles. $1,500.00
3.3 To construct shower kerb with tiles finished . $100.00
4) Bathroom 2 ( 2nd Storey Bedroom 2 )
4.1 To apply bonding agent with skim coat smooth plastering finished to wall. $600.00
5) Bathroom 3 ( 3rd Storey Bedroom 3 )
5.1 Supply and install 300 x 300mm homogeneous floor tiles. LS $400.00
5.2 Supply and install ceramic/homogeneous wall tiles. LS $1,250.00
5.3 To construct shower kerb with tiles finished . LS $100.00
5.4 Supply and apply waterproofing membrane to 2 Bathrooms. $300.00
6) Balcony
6.1 Supply and install 300 x 300mm homogeneous floor tiles c/w skirting to 2 Balcony. $900.00
6.2 Supply and apply waterproofing membrane to 2 Balcony. $160.00
7) Roof Garden
7.1 Supply and install 300 x 300mm homogeneous floor tiles c/w skirting. $1,500.00
7.2 Supply and apply waterproofing membrane to 2 Bathrooms. $350.00
8) FLOOR FINISH & STAIRCASE
8.1 Supply and install Laminate flooring c/w skirting to 4 Bedrooms, Hall and Landing. $3,000.00
8.2 Supply labour and material to sand down and apply black paint to existing wrought-iron railing. $900.00
8.3 Supply and install new timber plank with black stain and varnish finishes over existing steps, to install cement board to paint to finish below timber plank vertical wall. $4,200.00
9) PAINTING LS $3,500.00
9.1 To apply oil-base sealer to false ceiling at Bathrooms, Kitchen and new walls.
9.2 To apply white emulsion paint to all ceiling.
9.3 To apply 'ICI' or 'Nippon' emulsion paint to all internal walls.
10) SHOWER SCREEN
10.1 To construct 'L' shape shower screen, aluminium frame with 4.5mm thk tempered glass and sliding door. ( Bathroom 1 & 3 ) $580.00 2set $1,160.00
11) PLUMBING WORKS. ( conceal )
11.1 Supply and install copper pipes for hot & cold water supply to Kitchen and 2 Bathrooms, cold water supply to Private Garden and Roof Garden. LS $3,200.00
11.2 Supply and install outlet PVC pipe for discharge to Kitchen and 2 Bathrooms, Private Garden and Roof Garden. $450.00
11.3 Supply labour to terminate inlet and outlet piping work at Bedroom 2's Bathroom. $80.00
11.4 Supply Labour to install pedestal bowl ( W.C ) at Bathrooms. 2set $240.00
11.5 Supply Labour to install wash basin and basin mixer. 2set $160.00
11.6 Supply Labour to install shower mixer and shower set. 2set $160.00
11.7 Supply Labour to install Kitchen sink, tap and fittings. 1set $80.00
11.8 Supply and install tap to Private Garden and washing machine at Roof Garden. 2set $40.00
11.9 Supply Labour to install bathroom accessories. 2set $100.00
12) ELECTRICAL WORKS ( conceal )
12.1 Lighting wiring point ( 1 way ) @ 65.00
12.2 13amp power point ( single socket ) @ 90.00
12.3 13amp power point ( double socket ) @ 100.00
12.4 SCV television point. @ 150.00
12.5 Relocation of lighting switch/socket @ 50.00
13) Miscellaneous
13.1 To sand down and varnish existing door panel and door frame. @ 60.00/set 8set $480.00
13.2 Chemical wash to all floor- and wall tiles, and general cleaning to whole house. LS $500.00
PART A - Total : $38,820.00
PART B - CARPENTRY WORKS
1) WET KITCHEN
1.1 Supply labour and materials to fabricate and install wall hung Kitchen cabinet c/w swing door in laminate finishes and ABS trimming. 7ft. $770.00
1.2 Supply labour and materials to fabricate and install 'L' shape bottom cabinet c/w swing door in laminate finishes and ABS trimming. 16ft. $1,760.00
1.3 Supply and install solid surface worktop c/w backsplash and front profile above 'Bottom' cabinet. 16ft. $1,280.00
2) DRY KITCHEN
2.1 Supply labour and materials to fabricate and install full height cabinet c/w swing door in laminate finishes and ABS trimming. ( with opening for fridge ) 8ft. $1,500.00
2.2 Supply labour and materials to fabricate and install top & bottom cabinet c/w swing door in laminate finishes and ABS trimming. 5ft. $1,100.00
2.3 To construct 'Island' unit c/w pull out drawers in laminate finish. 5ft. $650.00
2.4 Supply and install solid surface worktop c/w backsplash and front profile. 10ft. $800.00
3) LIVING
3.1 To construct wall feature in veneer/laminate finishes c/w wiring compartment for wall hung T.V. 8ft. $1,440.00
3.2 To construct wall hung T.V console in veneer/laminate finishes c/w drawer and glass panel. 9ft. $1,170.00
4) MASTER BEDROOM
4.1 To construct wardrobe c/w hanger rod, shelves, drawers and swing door in laminate finish. 10ft. $2,200.00
4.2 To construct wardrobe c/w shelves, drawers and swing door in laminate finish. 5ft. $1,100.00
4.3 To construct tall storage cabinet c/w shelves and swing door in laminate finish. 4ft. $880.00
4.4 To construct wall feature in veneer/laminate finishes, with wiring compartment for wall hung T.V. 6ft. $1,080.00
4.5 To construct wall hung T.V console in veneer/laminate finishes c/w drawer. 5ft. $650.00
4.6 Dressing table with mirror at Changing room. est. $800.00
5) MASTER BATHROOM
5.1 To construct suspended vanity cabinet with drawer and swing door in laminate finish. LS $450.00
5.2 To supply and install 'Black' glass vanity top c/w backsplash. $300.00
5.3 Supply and install mirror above vanity. $280.00
6) BEDROOM 4
6.1 To construct wardrobe c/w hanger rod, shelves, drawers, mirror and swing door in laminate finish. 6ft. $1,320.00
7) Bathroom 3 ( 3rd Storey Bedroom 3 )
7.1 To construct suspended vanity cabinet with drawer and swing door in laminate finish. $400.00
7.2 To supply and install 'Black' glass vanity top c/w backsplash. $280.00
7.3 Supply and install mirror above vanity. $220.00
PART B - Total : $20,430.00
PART A + B - Total : $59,250.00
Edited by SmartFool
hey there
the most decent one that i got
and its not only the price
the quality of his previous works are really good
cos he did a few of my wtbs frens homes liao
maybe i shuld go look for electrician eric man
Edited by SmartFool
just a backdrop
i did some homework
and if anybody needs to check quotes
can refer to them as well
http://www.renotalk.com/forum/index.php?showtopic=13850 – sequence for renovation
http://www.renotalk.com/forum/index.php?sh...c=7184&st=0 – best quote
http://www.renotalk.com/forum/index.php?showtopic=13360
http://www.renotalk.com/forum/index.php?showtopic=13700 – kenna chop carrot
http://www.renotalk.com/forum/index.php?showtopic=13827
http://www.renotalk.com/forum/index.php?showtopic=15323 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=15344– use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=15120 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14335 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14625- – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=15128 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14662 – use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14578– use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14631 use as comparison for quote
http://www.renotalk.com/forum/index.php?showtopic=14593
1 toilet approx 3k
http://www.renotalk.com/forum/index.php?showtopic=14978 – Electrician cost
http://www.renotalk.com/forum/index.php?showtopic=14583 – tempered glass backing
http://www.renotalk.com/forum/index.php?sh...=13307&st=0
http://www.renotalk.com/forum/index.php?showtopic=14808 – 25k reno for 2 toilets and mbr
http://www.renotalk.com/forum/index.php?showtopic=14587 – haulage
http://www.renotalk.com/forum/index.php?showtopic=13991 – 24k quote for whole place
http://www.renotalk.com/forum/index.php?showtopic=13473 – for 3 room quote
http://www.renotalk.com/forum/index.php?showtopic=12950 – guide to reno
http://www.renotalk.com/forum/index.php?showtopic=13706 – adjustments in quotations
http://www.renotalk.com/forum/index.php?sh...1925&st=240 – blum, hettich
I see. I guess more importantly is the quality. This contractor that I'm waiting for is also pricing higher than the ID who has still yet to show me the drawings after so dam long (almost a month). His workmanship is there and we are comfortable with him.
No point choosing a cheaper one then later cry over it...
Edited by typhoonz
woh woh
come on cool it on the body
not that close means ur young
hey thanks for your recommendations for the sofa!!
check out our new dining table!!
one look at this table i know its from Evov :notti:
then follow your thread, yup bingo!
around $1500 right? hehe think i saw most of the tables at Evov already
this is a nice piece :good:
SF, Im not too sure how I can help out with your reno quote since I didn't do much for my current place.
But you can outsource some of the things out to others who charge cheaper. This way you can save a bit but the co-ordination you got to be around to see the work done accordingly. :)
yeah typhoonz agree with you
Bun2 thanks
i will contact the electrician given by some of the forummers
settee we will outsource also
Yang Guo
yeah its from Evov
but its 2k cos we go the 1.8m one
My quote today
very sian
1) HACKING AND HAULAGES - no comments as i didn't do anything like this
Living, Dining, Kitchen - how much $$psf tile can you choose? can choose $16psf spain homo tiles?. do you need a fridge / washer base?
3) Bathroom 1 ( 2nd Storey Master Bedroom ) - how much $$psf tile can you choose?
4) Bathroom 2 ( 2nd Storey Bedroom 2 ) - sounds reasonable
5) Bathroom 3 ( 3rd Storey Bedroom 3 ) - how much $$psf tile can you choose?
6) Balcony - how much $$psf tile can you choose?
7) Roof Garden - how much $$psf tile can you choose?
8) FLOOR FINISH & STAIRCASE - sounds reasonable
9) PAINTING - how much more for sealer for all internal wall? how many colours can you choose? how much more for each colour? how much more for better grade paint?
10) SHOWER SCREEN - thought show screen usually 10mm? what is the total length of the 'L' shape? better have that in B&W.
11) PLUMBING WORKS. ( conceal ) - does the quote include making good of hacked walls to conceal the pipes? as yours in a house, it's pretty difficult to comment as i don't know how long the pipes need to be. thought WC installation is much cheaper? some company offer free installation with purchase of WC. can bargain for the installation of misc fittings to be free?
12) ELECTRICAL WORKS ( conceal ) - does the quote include making good of hacked walls to conceal the wires? maybe it's more expensive because of the hacking and making good.
13) Miscellaneous - sounds reasonable as it'll be much more expensive getting new doors. general cleaning should cost that much for your floor area.
1) WET KITCHEN - - not too sure what's the price like now. when i did mine about a year ago, it was $100pfr because mine are all drawers. what's the brand of the solid surface and how much topup for a better brand or another material?
2) DRY KITCHEN - you are closing your fridge into the cabinet? that might not be advisable as the heat might be trapped. what is the measurement of the island unit? usually should be 4ft wide. if only 2ft wide, then cost should be same as kitchen cabinet at $110pfr instead of $150pfr
3) LIVING - didn't do so don't know market price ;p
4) MASTER BEDROOM - again, if workmanship is exceptionally good, then price is okay. my wardrobe was $200pfr. all full height?
5) MASTER BATHROOM - mirror expensive, can get yourself at kelantan lane for less. the rest looks reasonable
6) BEDROOM 4 - same as MBR
7) Bathroom 3 ( 3rd Storey Bedroom 3 ) - same as MBR
Edited by applefreak
Hi AF
thanks so much for the info
for the tiles its around 3 bucks psf from wat he said
painting i will have to ask him
shower screen also must ask
electrical and plumbing works all include conceal
thats why i also confused on the price
wil try to squeeze him
wet kitchen no info on pfr yet
haven asked abt solid surface as well
but i will definitely be getting granite top
oh the dry kitchen fridge that one cancel cos they misunderstood us
agree with the wardrobe as i told him 200 pfr at most
2nd quote will be on tues/wed since we deleted some stuff and added some
thanks AF
appreciate it!!
:dancingqueen:
