big_daddy 0 Report post Posted April 16, 2008 Found it to be struggle to run cables through my false wall for my TV and equipment.Is there any tips or tools to ease this process? I need to pull thru some HDMI cables, my tv has been mounted and can't imagine the nightmare of going thru the process again. !! Share this post Link to post Share on other sites
kriegs 0 Report post Posted April 16, 2008 Found it to be struggle to run cables through my false wall for my TV and equipment.Is there any tips or tools to ease this process? I need to pull thru some HDMI cables, my tv has been mounted and can't imagine the nightmare of going thru the process again. !!make use of existing wire that is being ran to pull thru new cable/wire. Use masking tape to secure both ends of the cable/wire. Abit of pull and push shld work.Not easy, so good luck. Share this post Link to post Share on other sites
big_daddy 0 Report post Posted April 16, 2008 make use of existing wire that is being ran to pull thru new cable/wire. Use masking tape to secure both ends of the cable/wire. Abit of pull and push shld work.Not easy, so good luck.Thanks... but if existing cables very short how? wait pull already existing cables also come out den die liao Share this post Link to post Share on other sites
XiaoQiang 0 Report post Posted April 16, 2008 Thanks... but if existing cables very short how? wait pull already existing cables also come out den die liaoHow about tie a string on one end of the cable and use the string to pull through the hole... hope this help. Share this post Link to post Share on other sites
fanguojun 0 Report post Posted April 16, 2008 i think it's difficult if your TV is currently mount to the wall as the hole which the wire goes through would most probably be right behind the TV. Guess you need to bring down the TV first. Alternatively, my electrician uses those white cable casing and guided the wires through but that is still with the TV being brought down first Share this post Link to post Share on other sites
kriegs 0 Report post Posted April 17, 2008 Thanks... but if existing cables very short how? wait pull already existing cables also come out den die liaoi guess u haf to use a dummy (rope or string) to pull in first, then use that for the other cables. Share this post Link to post Share on other sites
