popeye gal
Popeye's Yacht
System 3 @ all best.. $2488. :yamseng:
dun't know is it a good deal anot.. :dribble:
most air-con about the same...
now you better plan how you want to run the air-con trunking with your ID. see how best you can hide all the trunking. The Air-con people all got a standard (easiest way) to run the piping, which might affect your deco....
If there any Leakage, the damage will be more serious than not cover up. :jawdrop:
Hi Popeye
Would you mind sending me your 3d drawing?
I have engaged an ID for my flat (677C) with the same slanted living room, and the living area is badly designed. It is suggested to have a false wall (horizontal to the window panels), but it has blocked out all the sunlight and wind from the windows, causing 2/3 of the living area to the maindoor to be dark.
Hope to see wat ur ID's design is.
Thanks
Hi Popeye
Thanks
hi inuya5ha,
Still haven't settle wif an design & ID yet... Your Id's design, which we also dun't like too... :sport-smiley-004:
This is one of ID's design durling my search for ID. You can take it as a refer.
Ceiling works starting soon yah?
btw, colors on the wall are really nice... :dribble:
Thanks.. :drunk:
Ceiling Work Done.. Just Have't install all the Downlight... :yamseng:
