alanong999
Good Renovation Work
have renovated my EA 131 Sqm at woodlands, which cost my only 23.7K..... unbelivable, but it real. Excellent workmanship and reasonable price. I will up load some photo when I have settle down. Plush Living Design is the company that renovated my unit. Try calling my contractor S** *******
[Phantom: Advertising content]
hi can pm me pictures and contractor's contact?
Thanx!
i leave everything to my Project manager and ID. I requested to do up my Masterbedroom, Kitchen and Living room. the rest i leave it to them. To me i care only the finish product. I told them wat i wanna do and they do it for me.
hi can share you pic and contractor's contact?
Thanx!!
Good reno and carpenter jobs done so far. This is the second time I've engage the contractor and carpenter to do my new house after very satisfied with their first job done at my previous flat.
B4 reno
Kitchen cabinets...
Edited by jaskel
Guest poetsdesign
This are my work done >>>>>>>
Masonry Works
To supply materials & labour to lay Polish Homogeneous tiles ( ≤$ 3.50/ sqft ) with skirting
****, Dining, Household Shelther & Walkway floor.
To supply materials & labour to construct one step platform in laminated flooring finish.
To supply materials & labour to lay non-slip homogenous tiles (≤$ 2.50/ sqft) at Kitchen floor.
To supply materials & labour to apply double layer water proofing membrane at Kitchen.
To supply materials & labour to construct H50mm cabinet base, side with tiles finish only.
To supply materials & labour to construct H50mm fridge base with tiles finish.
To supply materials & labour to construct H50mm washing machine base with tiles finish.
To supply materials & labour to construct 02 nos H50mm shower kerb at Master Bathroom.
To supply materials & labour to alter of existing Main Gate.
Plumbing Works
To supply materials & labour to replace existing whole house water pipe to copper pipe.
To supply materials & labour to install concealed drainage pipe for new sink and washing machine.
To supply labour to install 02 nos instant/ 01 no tank heater at Master Bathroom & Common
Bathroom.
To supply labour to install Kitchen sink & tap after carpentry work.
To supply labour to install Bathrooms' accessories.
Aluminium / Wrought Iron / Glass Works
To supply materials & labour to install BA aluminium window grilles for whole unit.
To supply materials & labour to install BA aluminium casement window in black tinted glass
without top hung at Balcony & Svc Balcony.
To supply materials & labour to install BA aluminium glass swing door c/w handles & hinges
at Kitchen Entrance.
To be continue..........
Ceiling / Plasterboard / Partition Works
To supply materials & labour to simple cornices ****, Dining & Study Room.
Door / Timber / Laminate Works
To supply materials & labour to install heavy duty laminated flooring at Study & 03 Bedrooms.
Miscellaneous
To supply materials & labour to paint whole house ceiling & wall using ICI emulsion paint.
To supply materials & labour to paint whole house gate, door, door frame, pipe & etc using ICI
gloss paint.
To supply materials & labour to lay cardboard protection after flooring work.
Acid washing for whole house to remove stains.
General Cleaning for whole house upon completion.
03 nos of SCV Points
03 nos of Lighting Points
Install 02 nos of wall fan
Install Whole Unit of Light Fittings.
Install cooker hood & cooker Hob & 01 no of Tel Point
Haulage Fee
Budgetary Carpentry Quotation
( Prices are subjected to change at final design & material stage )
Kitchen
Design, fabricate & install top & bottom kitchen cabinet with laminate & white PVC carcass finish
c/w ABS trimming laminated door, designer handles & cutlery tray.
To supply & install heavy duty 16.5ft Solid-Surface Worktop
To supply & install 1 set of 2 ties stainless steel dish rack
Bedrooms
Design, fabricate & install built-in-wardrobe in laminate & white PVC carcass finish.
Size: L1650 Full Height
Design, fabricate & install built-in-wardrobe in laminate & white PVC carcass finish at Room 2.
Design, fabricate & install built-in-wardrobe in laminate & white PVC carcass finish at Room 3.
Size: L1800 Full Height
Design, fabricate & install sliding door c/w door frame in laminate, glass & heavy duty top hung
track finish.
Design, fabricate & install study ledge in laminate finish.
Master Bathroom
Design, fabricate & install suspended vanity cabinet in laminate finish.
That all, but almost whole house done.......
Can you give me the pic please
hi smartfool.. i believe they do.. they are ID cum contractor firm ma.. gif them a call ba.. i juz PM you..
Hi Tommy_Moby, let me have contractor HP? Thks
hi softball.. PM me ur email.. i show you some of my pic i haven taken.. =)
Hi Tommy_moby
Do you mind emailing me your contractor contact & some pics?
Thanks so much!!
Email to: Chieleebashi@gmail.com
B4 reno
Almost complete. Usually inside are those white color board which will turn yellowish over the yrs. This carpenter lady give me this laminate inside FOC even I didn't ask for it. I found out only when I was taking the photo.
Kitchen cabinets...wonder how to maximum the corner areas.
Solution she came out with...easy storage and accessible.
Please PM me the contacts.
Regards,
GK
hihi tommy_moby.. can u pls email me pics of ur house + reno quote?
my email is chieleebashi@gmail.com..
many thanks in advance! :)
B4 reno
Hi. Looking to change laminates on my current wardrobes too. Can pm contacts or send it to forjononly@hotmail.com?
Thanks!
