alanong999
Good Renovation Work
have renovated my EA 131 Sqm at woodlands, which cost my only 23.7K..... unbelivable, but it real. Excellent workmanship and reasonable price. I will up load some photo when I have settle down. Plush Living Design is the company that renovated my unit. Try calling my contractor S** *******
[Phantom: Advertising content]
Edited by Phantom
Guest tommy_moby
i had just done up my reno too.. really wanna give credit to my ID firm (astute works). excellent workmanship and reasonable pricing. call the person in charge, D***** 9*******. PM me and i can show you some pic i have taken. =)
[Phantom: Advertising Content Removed]
Edited by Phantom
This are my work done >>>>>>>
Masonry Works
To supply materials & labour to lay Polish Homogeneous tiles ( ≤$ 3.50/ sqft ) with skirting
****, Dining, Household Shelther & Walkway floor.
To supply materials & labour to construct one step platform in laminated flooring finish.
To supply materials & labour to lay non-slip homogenous tiles (≤$ 2.50/ sqft) at Kitchen floor.
To supply materials & labour to apply double layer water proofing membrane at Kitchen.
To supply materials & labour to construct H50mm cabinet base, side with tiles finish only.
To supply materials & labour to construct H50mm fridge base with tiles finish.
To supply materials & labour to construct H50mm washing machine base with tiles finish.
To supply materials & labour to construct 02 nos H50mm shower kerb at Master Bathroom.
To supply materials & labour to alter of existing Main Gate.
Plumbing Works
To supply materials & labour to replace existing whole house water pipe to copper pipe.
To supply materials & labour to install concealed drainage pipe for new sink and washing machine.
To supply labour to install 02 nos instant/ 01 no tank heater at Master Bathroom & Common
Bathroom.
To supply labour to install Kitchen sink & tap after carpentry work.
To supply labour to install Bathrooms' accessories.
Aluminium / Wrought Iron / Glass Works
To supply materials & labour to install BA aluminium window grilles for whole unit.
To supply materials & labour to install BA aluminium casement window in black tinted glass
without top hung at Balcony & Svc Balcony.
To supply materials & labour to install BA aluminium glass swing door c/w handles & hinges
at Kitchen Entrance.
To be continue..........
Ceiling / Plasterboard / Partition Works
To supply materials & labour to simple cornices ****, Dining & Study Room.
Door / Timber / Laminate Works
To supply materials & labour to install heavy duty laminated flooring at Study & 03 Bedrooms.
Miscellaneous
To supply materials & labour to paint whole house ceiling & wall using ICI emulsion paint.
To supply materials & labour to paint whole house gate, door, door frame, pipe & etc using ICI
gloss paint.
To supply materials & labour to lay cardboard protection after flooring work.
Acid washing for whole house to remove stains.
General Cleaning for whole house upon completion.
03 nos of SCV Points
03 nos of Lighting Points
Install 02 nos of wall fan
Install Whole Unit of Light Fittings.
Install cooker hood & cooker Hob & 01 no of Tel Point
Haulage Fee
Budgetary Carpentry Quotation
( Prices are subjected to change at final design & material stage )
Kitchen
Design, fabricate & install top & bottom kitchen cabinet with laminate & white PVC carcass finish
c/w ABS trimming laminated door, designer handles & cutlery tray.
To supply & install heavy duty 16.5ft Solid-Surface Worktop
To supply & install 1 set of 2 ties stainless steel dish rack
Bedrooms
Design, fabricate & install built-in-wardrobe in laminate & white PVC carcass finish.
Size: L1650 Full Height
Design, fabricate & install built-in-wardrobe in laminate & white PVC carcass finish at Room 2.
Design, fabricate & install built-in-wardrobe in laminate & white PVC carcass finish at Room 3.
Size: L1800 Full Height
Design, fabricate & install sliding door c/w door frame in laminate, glass & heavy duty top hung
track finish.
Design, fabricate & install study ledge in laminate finish.
Master Bathroom
Design, fabricate & install suspended vanity cabinet in laminate finish.
That all, but almost whole house done.......
i had just done up my reno too.. really wanna give credit to my ID firm (astute works). excellent workmanship and reasonable pricing. call the person in charge, Darren 90267764. PM me and i can show you some pic i have taken. =)
show me the pic.. hee...:yamseng:
Masonry Works
Plumbing Works
Bathroom.
Miscellaneous
gloss paint.
Haulage Fee
Kitchen
Bedrooms
track finish.
Master Bathroom
pic pls... let us see the beautiful house..
Guest tommy_moby
hi softball.. PM me ur email.. i show you some of my pic i haven taken.. =)
Guest tommy_moby
done... juz emailed you..
Hi Tommy, I had PM you my email add. Kindly let me see some pics of your new house. Thanks:)
Guest tommy_moby
emailed liao.. done..
Hi Tommy,
just pm u oso..
thanks a lot.
