hobbes187
Hobbes187's Stomping Ground
Today went to Choo Chiang and go this... A Hager timer switch for my foyer light. It will be fixed into the MCB box and the light will auto turn on everyday for a certain period of time. :) Have been looking for something like this for a long time cos I want a timer switch that is neat and concealed, not those bulky timers sold in DIY shops.
Thanks, we like it too :)
Haven seen u around for a while... Hows your reno progressing?
yeah, we went away for holiday.
Meeting Steven tmr to see 3D drawing again.
Nothing has began, but i think they have hacked the walls that are supposed to be do so.
Your reno progress looks good. :good:
Take more photos. They are captivating. :thumbs up:
Final colour scheme confirmation :) Courtesy of ICI design service.
Living rm - Sandstone + lily white
Finally decided on sandstone over mocha delight due to its lighter shade...
MBR - Natural linen + lily white
Guestroom - Bracken sand + lily white
Study room - Vintage yellow (Not sandstone as stated in pic) + pure white
I think vintage yellow looks better with pure white than lily white...
Edited by hobbes187
Some updates on the progress over the last week...
Tiling
95% of tiling work have been completed, the only things left are the touching up, the bomb shelter and some wall tiles in the toilet to be done up after my ventilation fan installation. The guestroom and study room tiles are done also. So tiling took 2 weeks to complete 95% instead of the 3 weeks planned.
Guestroom
Study room
Electrical works
Went down over the weekend and was surprised that electrical works have started. It wasn't slated to begin for another week so this was way ahead of schedule :good:
Wiring for L-box in living area
Wiring for dining area false ceiling
Wiring for MBR false ceiling
Shifting of power points and SCV points in study room. ID suggested routing the wires under the tiles thru PVC pipes and the result is much less trunking :) I'm glad the wires are neatly punched through the walls instead of going around the room...
Complaints
Not everything can be swee swee while doing reno. This is our main complaint of the day - a drainage point in the kitchen not done to my expectation. We feel that this part can be done much better. Firstly they should not have used the white colour cover cos it is too much of an eyesore. Secondly, the vertical removable tile is not well done and it doesnt sit snugly in the hole. Instead if I push it, it will become slanted. :furious:
Complained to ID and he promised me he will get them to redo the whole thing. He propose using a removable tile to replace the white cover (since it is elevated and probably wont be needed for drainage. He will also get them to do up the vertical portion properly.
Yeah the 3D drawing seems to be very slow recently. We are wtill waiting to view a revised version cos we decided to change all the laminates we chose initially, added a TV feature and changed the wall colours :) Do post up your 3D drawings even if they dont match your taste so we can give u some comments :notti:
We havent had the soft copy yet. Perhaps will ask for it from Steven the next time I am going to meet him.
Looks like your reno is progressing quickly.
They dont have the soft copy... They wont give the intermediate copies to you unless u ask cos they have to scan then email you.
Is it? I tot Steven told me they have leh. Ok. I shall sms him tmr. wahaha...
My toilet ventilation fan was installed today and my ID supervised the installation. He asked me to go down and take a look after work cos he felt that the top hung window is a bit stiff when opening and he held back payment to Central Aluminium in case I want them to rectify anything
So I went down just now armed with a torch light and groping in the dark. I found that it wasnt as stiff as I expected and only a little resistance was felt probably due to it being new. So I guess my ID has higher standards than me. I called him up and told him to pay Central as the windows are quite ok to me.
I like the fact that the fan they used were the larger KDK model and seems much better than the one I have at my current place. With the top hung window, the toilet looks brighter too. Will take picture the next time I'm at the site. Cant really see much to comment on the workmanship or material of the window. Also, my ID got his own tilers to touch on the areas surrounding the window so hard to tell who's workmanship it is
Anyway, anyone has any idea how I can limit the extent that the top hung window can be pushed out? I dont want it to be able to open all the way out. One way I thought of is to get my ID to drill 2 screws into the window track at each side so as to block the rail from going all the way up.
Edited by hobbes187
Today my ID's aircon contractor came to do up the trunking so I went down and discussed with him how my trunking should be run. Its not easy coming up with a good solution!
At the same time I took some photos while I was there. My ventilation fan was fixed on tuesday but I didnt see it clearly till today. The windows were done by a contractor I found myself but my ID got his men to hack the surrounding tiles and retile them after the installation :good: The window guy actually said he may not damage the tiles but my ID insisted on hacking the surrounding tiles away cos he say he wanted the window installed properly and nicely.
The workmanship seem good enough. No complaints from me on Central Aluminium :) The fan they gave was KDK 20WUD which is the biggest in the KDK window mount series and can suck more air. Casement window + fan cost $214 per set.
MBR toilet
Common toilet
Close up of fan
View from outside - Seems like there is a cover for the fan. Need to figure out how it works.
KDK 20WUD
Edited by hobbes187
The ugly drainage in the kitchen I complaint about was also replaced with a L-shaped tile. Now it look so much better right? I also went to buy 3 stainless steel floor traps to replace all the plastic floor traps in the toilet :) Will need the tilers to fixed them up for me.
BEFORE
AFTER
