greentea
Blk 3 Ghim Moh Rd
Hi mr chong,
finally after failed my re-sale flat at marine creasent. i finally found new unit at Ghim moh. will get my key somewhere in may 2008. Pls advise me on this thanks..
- The main door facing south east. reading taken from standing at main door inside the hse.
- My birth 10 Oct 1978 , my son 17 Feb 2005 and my wife 5 Sept 1977 .
- The blk is Blk 3 at ghim moh rd, this unit is at 15 floor , next to corner.
- this is not the original floor plan, got it from other forumer.. thanks
this is the floor plan.
this is the streetdirectory map::
Edited by greentea
Hi mr chong,
Hello
South East how many degrees?
Blk 2 is facing which part of your house?
Hello
hi chong,
south east degree 130 - it showing straight south east
the block 2 is facing back of my unit. backside face backside. is it not ok? very worry cost bought oredy..
hi chong,
Hello
It is alright if your unit can see blk 2 directly. From floorplan, seems like your back unit is looking into partial empty space and not completely blocked by blk 2. If you're not sure, can take a pic and put up.
Place some plants on the left side of your main door. The TV area in your sketch, replace it with a fish tank or water feature.
Place some white pebbles on the floor at the kitchen washing basin. Seems like you have 2 doors to the masterbed. Don't use the door leading from te kitchen. Display some metallic objects near to the window area of your masterbed. If you like animals, put a goat there.
Pick a book or two and you should be able to handle some of the common "Shas".
Hello
thanks for replying mr chong,
seems like the drawing create alot of "sha's chi" .if the tv and the sofa is not the right place to put to, which part of the house do u think i should put?
becos im buddism "quan ying" . im not allow to put fish tank. water feature without fish will that look good?
about the 2 door to the masterbed , its actually a shower and toilet. i forgot to put the picture in. so if thats the toilet about the metallic objects u think still applicable?
regards,
regards,
Hello
No, I didn't say that the TV and Sofa were in the wrong place. I only asked you to put the water feature at the location where the TV was drawn in the picture. You can put the TV anywhere in the living room.
Yes, a water feature will do.
So its actually a toilet. Then ignore the door usage.
You still need to put up the metallic object. It has nothing to do with the door.
Hello
ic thanks for replying..
so the unit suitable for my family?
Hello
It is alright. If you want to check out more, try taking some pics from your main door of the exterior of your house, corridor surroundings, load them up and I'll see wht I can help.
Basically, since you should be shifting in this year, keep the South area/ bedroom beside main door quiet and North area also. If you are renovating whole house, then never mind.
Hi Greentea,
Sorry for interupting into this post, i don't understand why buddism "quan ying" can't rear fish? Are you having altar at home? I have an altar but i intend to have a water feature with goldfish inside, cannot also?
regards,
