LadyLuck 0 Report post Posted February 21, 2008 as above, any macbook user have this problem, duno wat gone wrong recently den i have such problem Share this post Link to post Share on other sites
applefreak 1 Report post Posted February 21, 2008 send it to apple centre for servicing lah Share this post Link to post Share on other sites
LadyLuck 0 Report post Posted February 21, 2008 their service centre is useless la, nowsaday so scare to send to service centre....you know about edison case la.... Share this post Link to post Share on other sites
applefreak 1 Report post Posted February 21, 2008 backup your data, lock your account and create a new account with no access to the files for them to do servicing Share this post Link to post Share on other sites
MaCe 3 Report post Posted February 21, 2008 their service centre is useless la, nowsaday so scare to send to service centre....you know about edison case la.... you also have those..... Share this post Link to post Share on other sites
LadyLuck 0 Report post Posted February 21, 2008 backup your data, lock your account and create a new account with no access to the files for them to do servicing they are good in tat mah. no matter wat u do they sure know how to unlock one. you also have those..... wait they take my photo & do someting with photoshop & load on web la, Share this post Link to post Share on other sites
applefreak 1 Report post Posted February 22, 2008 if you really worried, then transfer your files to a external HDDdo a clean reload of the OS, should be safer liaoif you really really really worried, go to disk utility under applicationsfind the one that overwrite your HD 37 times onesure your files won't leak liaobut it'll take about a day to run me sent my one to the AMK one, no problem lahwe not celebrity mah Share this post Link to post Share on other sites
LadyLuck 0 Report post Posted February 22, 2008 what is the cause of macbook to heat up immediately after power on ?isit background there software running? Share this post Link to post Share on other sites
applefreak 1 Report post Posted February 23, 2008 actually macbook and macbook pro had heat problems coz of the heat sink locationthe vent for heat dissipation is in between the keyboard and the screeni know that the problem can be alleviated to a certain degree after changing the motherboard, but the heat problem will still be thereso the thing is if the heat problem wasn't there until recentlyor after you updated your softwarethen better to send it indid you buy applecare? Share this post Link to post Share on other sites
Brainstorm 0 Report post Posted February 24, 2008 Do you feel the fan working? any hot air blowing out at the rear base hinge joining the LCD display? Share this post Link to post Share on other sites
LadyLuck 0 Report post Posted February 24, 2008 finally i found the root cause at the monitor activity.its the printer job take up alot of cpu space tat cus the fan noise so loud . gosh finally..thanks! Share this post Link to post Share on other sites
floppy 4 Report post Posted February 27, 2008 (edited) off-topic:applecare (for the laptop/desktop) is a must even though it seem ridiculously expensive (without discounts).i have always utilize it to the max for my ibook and imac. hopefully, it won't be needed on my macbook pro (although i seriously doubt it). the only occasions where it didn't pay off were for the ipods. Edited February 27, 2008 by floppy Share this post Link to post Share on other sites
applefreak 1 Report post Posted February 27, 2008 i'm quite sure you'll find it usefulbetter have it and not need it then need it and not have it Share this post Link to post Share on other sites
