lxiul 0 Report post Posted February 18, 2008 can anyone kindly help explain to me how the aircon piping shld run if install my aircon unit at these x locations on my floorplan? Share this post Link to post Share on other sites
yoongf 11 Report post Posted February 19, 2008 I dun think is wise to place the fan coil in bedrooms at the proposed location. It means that the fancoil will be either above the bed or blowing directly at the bed. There will also be noise issues to consider. Aircon have moving parts, after 3 yrs.. motor noise will be louder, airflow noisier.It is preferred to place them above the door, and blowing wind at passageways rather than the middle, as far away from the bed as possible. Share this post Link to post Share on other sites
applefreak 1 Report post Posted February 19, 2008 btw, it's almost impossible for us to give any suggestions as there may be beams across the top which we can't see from the flr planbest to get your contractor/ID or air-con installer to advise you Share this post Link to post Share on other sites
lxiul 0 Report post Posted February 19, 2008 I dun think is wise to place the fan coil in bedrooms at the proposed location. It means that the fancoil will be either above the bed or blowing directly at the bed. There will also be noise issues to consider. Aircon have moving parts, after 3 yrs.. motor noise will be louder, airflow noisier.It is preferred to place them above the door, and blowing wind at passageways rather than the middle, as far away from the bed as possible.thanks for the advice yoongf, i did not realise it at all. now i must consider where i will be putting the beds in the room first.btw, it's almost impossible for us to give any suggestions as there may be beams across the top which we can't see from the flr planbest to get your contractor/ID or air-con installer to advise you hi applefreak, ya quite true beams are invisible in the flrplan and i also forgot abt it as we cant drill thru the beams.now i have headache where to put the aircon in the living/dining area as there is a beam in the centre. any idea if the fancoil in the dining area just outside the toilet wall is feasible?but i dun think i will on it when i am having dinner haha.. my food will turn cold very soon.wat abt if i place the fancoil above the balcony wall? is it allowed? Share this post Link to post Share on other sites
