wiredchaos
Is Plastering Of Ceiling Ok ?
Hi everyone, i was told by my ID that plastering of ceiling is so called "not approved" or in the grey area by HDB ?
But she say can oso do la but not advisable cos in time the plaster will peel off?
any comments ?
any comments ?
Hey wiredchaos,
- if ur wall is made-up of light-weight precast wall (hollow internal), u will most probably see e jointing groove line, unless hdb or previous owner oleady use plaster 2 filled e grooves.
If not, dis is wen cement plastering cums in to fill e grooves.
- if ur wall is made-up of concrete hollow block, u will most probably see e uneveness of e wall wen u lok at it sideways, unless hdb or previous owner oleady done 'smooth finish'.
If not, dis is wen plastering cums in to smoothen e wall.
It can be done either by (1)normal cement plastering or (2)chemical smooth finish.
Depends on own budget, esthetic or design.
Under hdb reno guidelines, It is allowed to cement plaster e internal walls of units.
- if ur ceiling (underside of slab of neighbour above) is those pre-stressed concrete plank, u will most probably see e jointing groove line, unless hdb or previous owner oleady use plaster 2 filled e grooves (by left).
Under hdb reno guidelines, It is not allowed to cement plaster e ceiling.
U may consider false ceiling to hide e groove lines. How deep e false ceiling, i'm sure ur ID/contractor wil b able 2 advise u.
Fyi, finished floor to underside of ceiling, clear height is min. 2400mm.
False ceiling is priced at $$$ x per sq feet. (Includes materials & labour, excludes light holders, fixtures & installation)
On y it is call 'grey' area, i gues its bcos, although it is clearly stated in e hdb reno guidelines, some ppl stil do it secretly. By rite canot, by left ppl do. Once get caught, both sides olso in trouble.
On 'wil e cement plaster on ceiling peel off overtime'? i gues it will.
mayb u wana checkout ->
HDB Flat General Renovation Guidelines
HDB Flat Electrical Renovation Guidelines
:yamseng:
Edited by jaCKY777
Hey wiredchaos,
:notti:
Thanks Jacky for yr in depth explanation.. really apppretiate yr kind effort.
But i guess it all boils dwn to " U can do it, but jus dun get caught" thingy. :deal:
But will skip the idea la since can save money and ceiling not tat jialat and can hide abit wif false ceiling.
