alexter
Alex's Harmony Home
well i turn on everything to the max.
and still low pressure water.
you know the tap with anti splash tap nozzle, i have to turn to max to see the bubble.
anything less then no bubble... sian....
well my neighbours same low pressure.
Hope they can turn up some pressure vales or the pump.
:unsure:
:lol:
i see, thats really bad, you really have to complain already.
hope everything goes well for your reno!
Well my reno so far so good. slow but good job so far.
The kitchen base is good and the aircon piping is perfect.
Here is a better photo and close up of my base.
Edited by alexter
Here the workers for the Air Con came at 10.30am.
and its finally show time for me.
because i spend 1 hr+ to discuss with the boss how to to run the piping and to have min piping last week.
here is all the pipings and equipments.
The first drill while the other measure for the next hole.
after four drill holes
then it is Hammer time!
then it is hole #2
Edited by alexter
here is hole #3 in the master bed room.
and hole #4 above the MBR toilet door. goes above the false ceiling.
and hole #5 to the outside.
and is drill from the inside above the toilet false ceiling.
and hole #6, for the water piping into the MBR toilet.
Edited by alexter
the drilling through the wall, metal plate then the tiles.
And hole#7 in the MBR for the aircon, which i did not take photo.
well with all these holes i run a very neat and simple piping for the 3 units.
the first 2 holes is directly out from the 2 bedrooms, so that my piping will go out direct from behind of the unit.
hence creating a perfect no piping in the 2 rooms.
Hole #1
hole #2
ok its getting late and i got no light up in the house yet.
so will have to continue later.
TOC soon.
Edited by alexter
Alex, i think your kitchen and mine is exactly the same design lei... LOL!
even the kitchen base also the same as my id had planned. will post my kitchen base when ready and we compare k... LOL!
:notti:
:sport-smiley-004:
the base same design... most of us at st64 doing the L-shape. hehehe
well you kitchen is so much bigger then mine.
i got problem putting in the big big mircowave oven in my kitchen.
super regretted for getting that oven.
now it makes my small kitchen even smaller.
but will slove that problem later when i meet my contractor.
now back to the Air con photo.
ok pipings out from hole #3
then into hole #4 and out hole #5
the is above the false ceiling.
this is my water piping runing slope down into hole #6
this will be hidden behind the wardrobe.
and the water pipe out into the drainage.
Edited by alexter
Here is the big compressor... Once again panasonic and its big, bigger then most other brand. (My big oven also panasonic)
the workers had a difficult time getting it out the window.
There are lots of shouting while they carry it out the window.
and finally it out.
Note to myself, and advise to others.
Don't buy over size things! :sport-smiley-004:
Edited by alexter
Harlow Alexter, saw in 1 of ur photos dat u haf a false ceiling or isit storage space in your toilet ceiling...
Can explain wat isit? (me curious cat :bangwall: ). It looks different frm normal false ceiling boards le...ru staying on top floor?
Btw, rem to keep ur controllers n wrap up ur aircon units with the plastic wor...will get dust stuck inside if not... :rofl:
Welcome to JurongWest!:sport-smiley-004::o
Can explain wat isit? (me curious cat :dancingqueen: ). It looks different frm normal false ceiling boards le...ru staying on top floor?
Btw, rem to keep ur controllers n wrap up ur aircon units with the plastic wor...will get dust stuck inside if not... :dancingqueen:
Welcome to JurongWest!:dancingqueen: !!
well i stay on top floor.
The false ceiling metal boards are standard for all units in these few blk in st64.
hi,
the air-con is within the ID package? Or you find yourself? can PM hw much the air-con cost.. and the contact of the whom you purchase the air-con. :dancingqueen:
well i have my contractor to get the air con an he arrange the people to install.
it the same price as what gain city or Best selling.
its least here i can arrange how the piping runs.
i saw a few of my neighbors with the same floor plan, and all got a standard piping trunking running through the rooms and a big loop in the master bed room. it is not that nice and difficult to hid.
i not sure the people at gain city will install the piping the way i wanted.
alexter,
thank for the infor. :notti:
so now so touch up of the holes and the final result.
here is the hole.
here is the patch.
and here is the final touch up.
here is the final pipes trunking outside my doors, which will be cover up with L-box
and the final pipes trunking inside the MDR, which will be cover up with wardrobe and L-box
Edited by alexter
