cueball
Help With This Quotation
Hi need a rough guide on the following cost.. Still in the mid of apporachin id/contractor to see the average out cost.. but tink maybe u guys can help with yr experience.. tks alot.
B HACKING WORKS
1 Demolish existing 2 x basins + vanity tables
2 Hacking of existing 6ft wall at master bedroom
C WET WORKS
1 Supply labour & overlay full ht ceramic wall tiles for 2 bathrooms (tiles:$2.50psf & below) 1
2 Supply & overlay 300mm x300mm homogeneous floor tiles for 2 bathrooms 1
(tiles $2.80psf & below)
D MASONARY WORKS
1 Supply labour & construct 5ft false wall using hollow block **** room 5
2 Supply labour & construct 4ft Gypsum board false wall at master bedroom 4
3 Supply labour & construct 6ft Gypsum board false wall at master bedroom 6
4 Supply labour & construct 5ft low wall using hollow block at master bedroom 5
5 Supply and over lay laminate flooring for master bedroom (including skirting) 335
6 Supply and over lay laminate flooring for bedroom 2 (including skirting) 154
7 Supply and over lay laminate flooring for bedroom 3 (including skirting) 154
E PLUMBING WORKS
1 Replace / extension of cold copper piping for kitchen sink & washing machine
2 Provide labour to install 1 kitchen sink & tap.
3 Provide labour to install mirror set and bathroom accessories for master toilet
4 Provide labour to install mirror set and bathroom accessories for common toilet
5 Supply & install PVC inlet & outlet drainage piping for kitchen.
F CEILING WORKS
1 Supply & install false ceiling or L-box light holder **** area
2 Supply & install false ceiling or L-box light holder at dining area
3 Supply & install false ceiling at bedroom passage area
G PAINTING WORKS
1 Supply painting of internal wall and ceiling for whole house using ICI emulsion paint
2 Supply painting of all d0;1J::1v.me, gat1. (iP~ etc ....
H ELECTRICAL WORKS
1 Supply labour to install 12 + 4 nos ceiling lights (Exposed trunking)
2 Supply labour to install door bell at existing point
3 Supply labour to instal! cooker hood & hob
I CUSTOMISED FURNITURE
1 LIVING ROOM
1 Design & fabricate 7ft TV console & full ht wall feature 7
2 Design & fabricate 4ft full ht shoes cabinet 4
2 KITCHEN
1 Design & fabricate top & bottom laminated cabinet with ABS 1 mm trimming 21
Designer handles Top 9
ABS Plywod door Bottom 12
: Unlimited shelves ~ c;s:
: Dish Drainer ..... ~ ~ 1
2 Supply & install solid Kitchen table top (Cresto) with back splash & apron 12
3 Supply & install 3ft tempered glass behind stove 3
3 MASTER BEDROOM
1 Design & fabricate a 11 ft walk-in wardrobe with metal supports as design 11
Unlimited shelves
2 Supply labour & construct 8ft x 5ft platform 40
3 Supply labour & install laminated flooring [supreme) for platform 40
4 Supply labour & construct 8ft x 2ft x 2ft cozy corner / storage area 8
4 MASTER BEDROOM TOILET
1 Supply & install 3ft vanity table [cement slab with solid table top) 1
5 COMMON TOILET
1 Supply & install 3ft vanity table (cement slab with solid table top) 1
J OTHER WORKS
1 Supply haulage and delivery of goods to site
2 Clear whole house debris
3 Wash affected area
4 Lay floor protection for affected area
5 Submission of HDB Permit Application
* ADDITIONAL I OPTIONAL ITEMS
1 WINDOW WORKS
1 Supply labour & install sliding windows (alum frame with clear gloss I at balcony
2 Supply labour & install window alum grills (black/sHver/bronze) at balcony
3 Supply labour & install sliding windows (alum frame with clear glass) at kitchen
4 Supply labour & install window alum grills (black/sliver/bronze) at kitchen
5 Supply labour & install sliding windows (alum frame with clear glass) at 4 bedrooms
6 Supply labour & install window alum grills (blaCk/silver/bronze) at 4 bedrooms
BTw my is a resale 5rm
I understand your concern on cost. All of us have limited $$$. But I would say it may be better to worry about other things, like quality and reliability of the contractor.
yup i do understand hat point.. now lookin for a super cheap deal, just wanna chk wht the norm for this kinda of reno..
B HACKING WORKS
C WET WORKS
D MASONARY WORKS
E PLUMBING WORKS
F CEILING WORKS
G PAINTING WORKS
H ELECTRICAL WORKS
1 LIVING ROOM
2 KITCHEN
3 MASTER BEDROOM
Unlimited shelves
5 COMMON TOILET
J OTHER WORKS
1 WINDOW WORKS
est ~ 27k
Hi cueball,
I think it would be easier & get more response if you specified (prefered itemised) the $ amount for the quotation you received. Also the type of materials it will be using.
Cheers
