MsPetite
Caring Of Laminates
Hi currently all my 3 bedrooms are covered with Firmaflor laminates. I've not officially move in but would like to know how do I care properly for laminate flooring? Can I mop and vacuum as per normal? Read from other threads that laminates can get scratches if vacuum suction is too strong. Anyone can advise me?
Thanks.
MsPetite
Mspetite,
My advice for you is that call the company that does the flooring for you and seek their professional advice.
But as far as I knew, the laminate flooring right, all you've to do is to sweep first, then used warm water to mop over.. please ensure your mop isn't too wet. Cos' when the water seeps into the gaps, it may caused the laminate floor to warp over time.
As for vaccuming the floor, I think, it shouldn't be a problem but make sure the flooring is scratch resistent before you used the vaccum cleaner on it. Carry the vaccum cleaner when you go thru the room and don't used too much force e.g. pressing the sucking brush onto the laminate flooring or dragging anythign across the floor.
