superrazorblade
Kitchen Sink Cabinet
Do you see a need to use tiles for the Kitchen Sink Cabinet?
We have a bad experience with our existing house sink. The cabinet keeps decaying because water keeps seeping into the cabinet. It is likely because we are currently using a cheap type of Laminate top.
We forgot to ask our ID/contractor during our initial quotation. Now my ID/contractor told me that in order to put tiles below the kitchen sink, we have to build concrete wall. And he mentioned that it costs more than 1k. Is this expensive?:sport-smiley-004:
He also mentioned that since we are using solid top and with undermount sink, there is no risk of water seeping in. Is that a correct statement?
Thank you.
Regards
hmm has price really gone up that much?
my concrete sink support with granite countertop is $1,080 :sport-smiley-004::rolleyes:
whether water seep in or not depends on a lot of factors
for instance, condensation at the bottom of the sink
or the sealant wears off, or unfortunately your water pipe burst :unsure:
Hi all,
I am having problem with my kitchen sink cabinet due to bad design. The wood unenderneath starts to rot as water seeps from the mixer tap pipe.
As such i am thinking of modifying the kitchen sink. Any kind soul can recommend a reliable carpenter/plumber with good workmanship? Do not want to go back to the same contractor who did the job:(
Work to be done :
1. To cut a bigger hole on the existing table top to accomodate the new sink. Existing sink is of undermount type, changing to drop in type.
2. To replace the rotten part of the wood if possible.
3. Redo the drain pipe etc as my current sink is of single bowl type, changing to double bowl.
Thanks.
Hi Apple
Yes, expensive to have concrete support.
But I am on for concrete support ONLY for basin and stove.
It is better to have concrete especially when water involved.
Over time, maybe 10 yrs, I afraid wood cannot stand the water!
The rest will be normal cabinet support.
Wow, $1,080 for concrete support, ard $150 pfr??
HAPPY
my concrete sink support with granite countertop is $1,080 :) :)
or the sealant wears off, or unfortunately your water pipe burst :jawdrop:
hi Apple,
Can I check with you - is your sink support using homogenious tiles ? if so, is it difficult to maintain ? does it get stains very easily ? oso, does the grouting between tiles get dirty easily ?
For my new place, my mum is considering doing tiles support for sink & stove cos it should be able to last longer. However, our kitchen may look very old-fashioned and also worried about the maintenance part.
Joseph
Hi Apple
HAPPY
my concrete sink support is using granite countertop so can't really answer your question
however, the tiled sides and bottom is quite easy to clean
won't consider concrete supports old-fashioned, just not 'in' now :thumbs up:
pix of my concrete sink support
before the sink was up
before the countertop was up
finished product
i hv concrete solid support for my sink+ stove too. not v big, same tiles as my homo wall tiles., no laminate. ID charged me 600$ for that. i got it at my parents' insistence because their sink @ home is rotting n having leakage problem coz is wood.
Usually mkt rate for concrete is around less than $150 pfr.
You need to know how many per foot for your sink + stove...then you will know how much your id charge you per foot run.
Hi applefreak
Thanks alot. A pic is worth more than a thousand words.
Now, I can see what this is all about.
Really like the color contract between your countertop and cabinet. SWEE!
Cheers.
Hi APPLE
My mum gonna have blue pearl for kitchen top.
For me...I will not use the same as my mum...maybe other if got the same price like Blue Diamond, Silver Blue, Midnite Blue or Steel grey.
Actully not many pple using blue pearl (too expensive), many opt for solid top.
HAPPY
hi louisebrown, thanks for your kind compliments :(:jawdrop::curse:
actually the better quality solid tops are more expensive than granite tops
corian by dupont, LG etc are around $140 pfr
think i really got a very good deal at $100 pfr for my countertop :):notti:
think it's really up to the individual bah
some prefer the beauty of natural stone - like me
some prefer the seamless and uniformed colour of solid top
won't consider concrete supports old-fashioned, just not 'in' now :dunno:
finished product
Thanks to all who replied to my queries.:thumbs up: I think I will need to ask my ID to install concrete bottom for the kitchen sink.
Anyone knows how much ur contractors or IDs charge for building a concrete bottom for kitchen sink? Any good recommendation for renovators who did kitchen sink at a reasonable price?
