marcus_tm 0 Report post Posted December 6, 2007 Can anyone recommend or setup a wireless router for my new hse?My new HDB already have those wiring & point done to all rooms , they got a central box ontop of the circuit box, inside are those ethernet points and telephone points. Hope you guys know what i meant. Will take a pictures soonThanks in advance cos i totally know nuts about this.pls advise Share this post Link to post Share on other sites
latitude 0 Report post Posted December 6, 2007 (edited) what ISP will u be using? I suggest you get a router from them and save the trouble of buying yrself if possible. bundle packages are very attractive esp now nearing Xmas, sure have promos.if you have to buy one yrself, then chk with the service provider the recommended brands/models. I ever bought one on my own and later SingNet says not compatible!I didnt know HDB also have ethernet points in all rooms?? U did it yr own?? Anyway, wireless routers will not need those points. Afterall, it's wireless mah Connectivity wise, just connect yr router to the tel point can liao and of course electricity. Configure the a SSID and a encryption key. Configure yr computer to detect the SSID and enter the encryption key. That's abt it. Nowadays, routers comes with setup wizards to walk you thru the steps. I find that SingNet supplied ones are very user friendly. Edited December 6, 2007 by latitude Share this post Link to post Share on other sites
MaCe 3 Report post Posted December 6, 2007 Can anyone recommend or setup a wireless router for my new hse?My new HDB already have those wiring & point done to all rooms , they got a central box ontop of the circuit box, inside are those ethernet points and telephone points. Hope you guys know what i meant. Will take a pictures soonThanks in advance cos i totally know nuts about this.pls advise just subscribe to singnet. problem solved. Share this post Link to post Share on other sites
marcus_tm 0 Report post Posted December 6, 2007 Think will check out singnet mio plan ask them install better.Hi Latitude ya my HDB flat has done it for us all the ethernet points, so save me all the wiring charges and ugly wiring casing, but now got wireless even better, at least i got 2in1 Share this post Link to post Share on other sites
TYM 0 Report post Posted December 10, 2007 Think will check out singnet mio plan ask them install better.Hi Latitude ya my HDB flat has done it for us all the ethernet points, so save me all the wiring charges and ugly wiring casing, but now got wireless even better, at least i got 2in1 !!I think most linksys router will be compatible. Just follow the installation CD provided to setup the router, very easy.Which HDB flat is this, have ready-laid ethernet points. Share this post Link to post Share on other sites
andylyf 0 Report post Posted December 10, 2007 yah, any wireless routers in the market will do. Remember to read up on basic wireless security to prevent pple from smooching / stealing your network packets. Share this post Link to post Share on other sites
Sharpion 0 Report post Posted December 21, 2007 you can try Dlink 655 this is the one i just bought after quite a lot of research on this subject - in case you see it, there are very chio looking Belkin routers but reviews have said their performance is very bad. Share this post Link to post Share on other sites
marcus_tm 0 Report post Posted December 24, 2007 I think most linksys router will be compatible. Just follow the installation CD provided to setup the router, very easy.Which HDB flat is this, have ready-laid ethernet points.Punggol , pardon me ,i hope i didnt see wrongly cos i see a telephone socket and a data/ethernet socket in everyroom living rm & kitchen & store as well. So the switch board area i guess is something like a hub etc. Share this post Link to post Share on other sites
TYM 0 Report post Posted December 24, 2007 Punggol , pardon me ,i hope i didnt see wrongly cos i see a telephone socket and a data/ethernet socket in everyroom living rm & kitchen & store as well. So the switch board area i guess is something like a hub etc.Saw your reno blog and dun think those are data/ethernet pts, just normal telephone socket, same as mine.Dun think HDB will lay ethernet points in HDB flats, especially with wireless router at such low prices, and IDA push to have wireless access all over Singapore. Share this post Link to post Share on other sites
tingshen 0 Report post Posted December 25, 2007 even the most expensive property in SG may not have ethernet cable built in. reason being, the speed keep going up, the cables are already obseleted the moment you installed them wireless is the way to go, provided it doesn't make us too prone to cancer hehe... Share this post Link to post Share on other sites
NiVleK 0 Report post Posted December 25, 2007 Ethernet points in all rooms by HDB? Dun think its ever possible for HDB to be so nice.Anyone can show some pictures? !! Share this post Link to post Share on other sites
marcus_tm 0 Report post Posted December 26, 2007 (edited) I completly a IT idiot pls advise me, this is the main hub . Hope pictures helps so can help me to solve this...HDB also provide us the ethernet cable as wellClose up Edited December 26, 2007 by marcus_tm Share this post Link to post Share on other sites
JIN 0 Report post Posted December 26, 2007 Those Data sockets should be the Lan Cables. However, I think they will most probably give us Cat 5 cables, which are good for 10/100 speed. The fastest at the moment is Cat 6 which is 10/100/1000. But unless you get the correct Lan Card / Router, there is no additional point for Cat 6. Share this post Link to post Share on other sites
marcus_tm 0 Report post Posted December 26, 2007 Those Data sockets should be the Lan Cables. However, I think they will most probably give us Cat 5 cables, which are good for 10/100 speed. The fastest at the moment is Cat 6 which is 10/100/1000. But unless you get the correct Lan Card / Router, there is no additional point for Cat 6.So i if i want all my rooms to access to internet, what shold i get to setup? A router? What will be a better choice? Pls advise, Thanks Share this post Link to post Share on other sites
MaCe 3 Report post Posted December 26, 2007 So i if i want all my rooms to access to internet, what shold i get to setup? A router? What will be a better choice? Pls advise, Thanksjust subscribe to either starhub or singnet, sometimes they do give router during promotions.your house is indeed very special! Share this post Link to post Share on other sites
