nimmy
Advice On Flooring
Hi all,
I have laminated flooring for my whole house.Can see some strips started warping.Is it possible to fix back those strips or do i need to change the strips?How is the laminated strips laid?Is it with the help of glue?
Thanks
as i know, to fix the laminate floor they need to take out from the nearest side, replace then put back again.
after sometimes laminate floor will change colour, so if you fix will not have the same colour.
