gumbokins 5 Report post Posted November 16, 2007 We had a solid stove support built and they made the hole to fit the hob. but when we put the hob in, there is a 1.5 inch gap in the width of the hole, and only about 0.5 inches of each end actually sits on the support. we can re-position the hob slightly to cover up the gap, but should the gap even be there, and should it be so wide? Also, as it's almost precariously being supported by just the ends, is that going to be stable enough, in case my mum decides to plop down one huge pot of lodeh on it?how are these things installed anyways? is any sealant or cement put along the edges? Share this post Link to post Share on other sites
MaCe 3 Report post Posted November 16, 2007 We had a solid stove support built and they made the hole to fit the hob. but when we put the hob in, there is a 1.5 inch gap in the width of the hole, and only about 0.5 inches of each end actually sits on the support. we can re-position the hob slightly to cover up the gap, but should the gap even be there, and should it be so wide? Also, as it's almost precariously being supported by just the ends, is that going to be stable enough, in case my mum decides to plop down one huge pot of lodeh on it?how are these things installed anyways? is any sealant or cement put along the edges?solid stove support as in those acrylic/plastic type? NON-concrete?then your contractor has cut the hole too wide - get them to change the top. Share this post Link to post Share on other sites
gumbokins 5 Report post Posted November 16, 2007 solid stove support as in those acrylic/plastic type? NON-concrete?then your contractor has cut the hole too wide - get them to change the top.no, solid as in brick and mortar kindof solid. Share this post Link to post Share on other sites
applefreak 1 Report post Posted November 16, 2007 then your contractor screwed upinstead of making the hole for the cut-out, he made the hole for the surface size of the stovethis is unacceptable !! unless your stove cut-out size is exceptionally small, the hole might be bigger to cater for future changes Share this post Link to post Share on other sites
gumbokins 5 Report post Posted November 16, 2007 so how much support is actually required for the thing to be stable? should the hob sit on the cut-out (sounds much nicer than 'hole', eh?) with at least a 1.5 - 2" border? Share this post Link to post Share on other sites
gumbokins 5 Report post Posted November 16, 2007 ok. nehmind. i just answered my own question. have to take out the tape measure and start measuring. i'm very sure the cut out is NOT 160 mm shorter than the stove.so in this case, how to rectify? add more bricks ah? ugg. Share this post Link to post Share on other sites
applefreak 1 Report post Posted November 16, 2007 the cut-out is actually the size of the bottom of the stovedifferent stove comes with different cut-out sizeideally, the cut-out of the support should fit the stove cut-out nicely i.e. the stove cannot shift at allbut allowance is usually given, around 1cm each sidefor concrete support, what's done cannot be undoneand the only way to rectify is to build from scratch again Share this post Link to post Share on other sites
gumbokins 5 Report post Posted November 16, 2007 or get a bigger stove then hor, are the edges sealed with sealant or are hobs just 'plug and play'? Share this post Link to post Share on other sites
applefreak 1 Report post Posted November 16, 2007 so far mine are all plug and playeasier to remove the stove for whatever purposesealant is more for sink where there's a lot of water Share this post Link to post Share on other sites
rummi 0 Report post Posted November 16, 2007 how abt asking your contractor to fabricate a timber-frame to the overly-large opening to reduce it to a 'fitting size' he will definitely know how to install the new frame VERY STUDILY ! so tis is not a mistake tat cannot be rectify- dun worry urself too much! Share this post Link to post Share on other sites
