Yang Guo
My Lovenest At Jalan Membina
xlan.. do u do backsplash also?
yup yup.. will b getting glass backing as well.. but not sure how it looks as well.. will update on my t-blog when it's done.. =)
Hi XLAN
According to my id, glass backing is better than SS.
Cos' easy to clean compare to SS.
And also look grand and stylish.
Btw...is it true that there are many colours to choose for glass backing?
Anyone?
HAPPY
Hi XLAN
Anyone?
HAPPY
mm.. each has it's pros n cons.. sama sama.. no such ting s tis is better than that.. cos glass u'd risk breaking it.. thou easier on the cleaning part.. but talking abt the cleaning part.. i rem someone (was it binzz?) mentioned tat contractor teached to use veg oil on kitchen paper to wipe it clean n shine on s/s surfaces.. i hvn't personally try it yet.. so still :sport-smiley-004: .. but s/s def won't shatter like glass.. 100% sure on tis.. hahahahaa..
anyway.. on the colors of glass... yes... basically is jus a layer of spray paint (contractor said is called 水漆) at the back of the glass.. so from front.. u c as colored glass.. mine will b a black 1.. :sport-smiley-004:
Ok thanks for your info.
I am going to have bright colour, not usual green colour. hehehe
mm.. each has it's pros n cons.. sama sama.. no such ting s tis is better than that.. cos glass u'd risk breaking it.. thou easier on the cleaning part.. but talking abt the cleaning part.. i rem someone (was it binzz?) mentioned tat contractor teached to use veg oil on kitchen paper to wipe it clean n shine on s/s surfaces.. i hvn't personally try it yet.. so still !! .. but s/s def won't shatter like glass.. 100% sure on tis.. hahahahaa..
anyway.. on the colors of glass... yes... basically is jus a layer of spray paint (contractor said is called 水漆) at the back of the glass.. so from front.. u c as colored glass.. mine will b a black 1.. :D
mm.. each has it's pros n cons.. sama sama.. no such ting s tis is better than that.. cos glass u'd risk breaking it.. thou easier on the cleaning part.. but talking abt the cleaning part.. i rem someone (was it binzz?) mentioned tat contractor teached to use veg oil on kitchen paper to wipe it clean n shine on s/s surfaces.. i hvn't personally try it yet.. so still :bangwall: .. but s/s def won't shatter like glass.. 100% sure on tis.. hahahahaa..
anyway.. on the colors of glass... yes... basically is jus a layer of spray paint (contractor said is called 水漆) at the back of the glass.. so from front.. u c as colored glass.. mine will b a black 1.. :unsure:
agreed with xlan. we won't be doing stainless steel / glass. will stick to the existing tiles or simply buy a alumiium sheet to cover there..
still "fan" over whether to do all concrete incl stove area or just sink support. any advise?
hi nemofc.. i guess.. hv to depend how much do u trust the contractor's carpentry work.. if u worried.. then get the sink area done with concrete.. concrete def last (near/almost) life time.. def is strong enough to hold anything any weight.. regardless of water/moisture..
but i guess i'm in no position to give advice.. cos i didn't do any concrete support in kitchen.. hahaha.. n if u ask y.. i also hv no idea.. jus nvr cross my mind tat i need a concrete support.. until i read this concern in the recent threads.. haha.. *scratch head*.. :P
personally, i think concrete sink support is good enough
sink area tend to have a lot of moisture so wood is not a good idea
stove wise, think cabinet should do the job liao :P
Yes sink cos of the moistures...
But stove...will prolong heat make the wood soft?
don't think so, heat will only make metal soft
never heard wood be become soft leh, decompose only :thumbs up:
really thanks for your comment.
cos' we might be doing more of cooking & oven, so worried that i might leave my hot plate on the solid top, will stain the top. heart pain then.
hehehe that's why i use granite countertop instead
how hot the pot also no worries :jawdrop:
but will have to choose granite top colour tat match with the tiles on the concrete support for sink lei. headache
if you have the budget, do what i did
use granite top for the concrete support also
probably another $400 blown but will look nice loh :jawdrop::bow:
probably another $400 blown but will look nice loh :bow::jawdrop:
:jawdrop: do you mean granite on the sink support or the stove area? we are using concrete support for sink area, and stove area, using solid top.
YG, sorry to side track here...
Edited by nemofc
