tension_z
Pls Comment On Quote, Thanks In Adv.
Some info. Pls comment on quote.
New Standard Flat ( no flooring done except for kitchen, and toilet)
Flat size : 90 m2
hacking works
1 hacking of exisiting L3ft at master bedrm $270
(exclude P.E fees)
Tiling works
1 Plaster smooth affected wall after hacking at master bedrm $110
2 Construct L4.5ft concrete sink support
by using 63mm hollow blocks and 300mm x 300mm homogenous tiles $850
3 Construct cement base for fridge ,kitchen cabinet and washing machine $390
4 Supply and lay homogenous tiles at bomb shelter $260
5 Supply and lay homogenous tiles **** and dining area $1850
Laminated Floor board
1 Supply and install selected laminated floor board at 3 bedroom including skirting $1620
(Range of Power Dekor laminated floor board to be selected)
Ceiling and Partition works
1 Supply and install flat false ceiling **** and passage to bedrms $730
2 Supply and install flat false ceiling at walk in wardrobe $120
3 Supply and install L14ft x H 8 ft pained partition wall for walk -in wardrobe at master bedrm $560
4 Supply and install L box ( depth 450 mm) at master bedroom $280
(note: price of L box exclude curtain pelmet
Glass works
Supply and install 2 no. of W 3 ft x H 6 ft x 10 mm fixed tempered clear glass at master bathroom $250
Plumbing works
1 Extend exisiting pipe to new kitchen sink position $80
2 Install 1 no. of kitchen sink and tap including connecting inlet and outlet pipes $150
3 Install 1 no. of storage heater $90
Install 2 sets of bathroom accessories $60
Carpentry works
Living Room
1 Supply and install L8ft full ht storage cabinet cum wall feature at household shelter entrance in selected
laminate finishes $1760
2 Supply and install L 6 ft TV console in selected laminate finishes $ 780
3 Supply and install L 6 ft x H 8ft TV feature wall in selected laminate finishes c/w groove line or stainless steel inlay design $1440
Kitchen
1 Supply and install L 15.5 ft top + L 8.5 ft bottom kitchen cabinet using laminated doors c/w ABS trimming,
selected handles, cutlery and drainage tray $2880
2 Supply and install L 13 ft Montelli solid surface worktop $ 1040
3 Supply and install 1 no. of L 4 ft X H 8 ft sliding doors by selected laminates c/w top sliding track $880
Master Bedroom
1 Supply and install 6 x vertical poles + 6 x haging rods + 8 x L3ft shelves + 1 x 3 tier drawer $1800
2 Supply and install L9ft study ledge in selected finishes $540
3 Supply and install 1 no. of L3ft x H7ft sliding doors by using selected laminates c/w top sliding track $780
Electrical Works
1 Shift and relocate 3 nos. of existing light point at bedrm 2 and living with installation @$30 per point $90
2 wire and install 10 nos of light points @ $55 per point $550
3 installation of 7 nos. of ceiling lights $ 70
4 add one single socket @ $45 per pt at fridge area $ 45
5 Add direct switch at cooker area $ 75
Misc
1 Painiting of walls and ceilings for whole house by using ICI emulsion paints (pentalite series) $1150
2Provide proetction cardboard and general washing $300
Total= $21850
Hi people,
any comments about the items in the qutation above?
basically, I am just doing an extra Walk in wardrobe, other than that,
it is quite basic.
is there any hidden items that are not in the quotation?
any items overcharged?
Thanks in adv.
Edited by tension_z
Flat size : 90 m2
hacking works
(exclude P.E fees)
Tiling works
Glass works
Plumbing works
Carpentry works
Living Room
Kitchen
Master Bedroom
Electrical Works
Misc
Total= $21850
Hi people,
it is quite basic.
Thanks in adv.
Ok here I go......1st quote I believe....I tell U....your price Si beh ex! we go line by line
Item one...hacking....hack 3 feet but pay like hacking the whole place...for that price...U can tear 2 bedroom walls down
Tiling....plaster...back damaged areas? Aiyo U know how cheap and how easy its done dare to charge 110 somemore
Your concrete kitchen sink support costs more than Stainless steel, you using Italian homo tiles ah?
Laminated Floor board....think u can easily shave another 20-30% off
cement bast $390.....tsk tsk tsk....
False ceiling works.......for me i will shave them 200-300 off their price
Glassworks.....ok
plumbing works....way above market rate.
Carpentry works.....can shave somemore.....another 20-30%
Kitchen.....Montellie SS...no brandname still so ex....press for 70/ft run
MBR Wardrobe...wah poles only so ex.....rather U go to the Cabninet specialists....for similar price scale
Electrical works can shave 5 bucks off per item
Generally your total can save a further 25-30%
Glassworks.....ok
hey there thanks for comment.
sad to say, this is last quote, not 1st quote.
I am wondering if it is expensive due to the reason that this is an ID firm.
pls advise, Thanks a lot.
is the painting cost normal for a 4 room to be 1150-1300? some can quote 800? y ah?
