Relacker
Need Help: Audio From Tv To Entertain System
hi,
i recently bought a sony lc 40 inch with hdmi and s sony entertainment system. The hdmi cable is connected.
the dvd movie played are all able to be heard over the sound system but not when i on the TV le. when i on the tv only the lcd TV has the sound but not the sound system.
i tot the hdmi alread take care of it or i still need to plug in red, yellow, white audio cable???
hi,
U dont have to plug in the Red, White and Yellow cables (Analogue Phono) but do u connect the Digital Coaxial to ur sys???
When u mention LCD got sound is it the DVD sound or only the TV channel sound?
Or worst case did u press ur LCD "AV" button. :)
Or worst case did u press ur LCD "AV" button. :dancingqueen:
TV got the TV sound when u watch the program, haha sound stupid when i typing it out.
But the entertainsystem dun have it when i turn the mode to TV.
yesterday i go p0ast harvey, ask a sales guy, he say have to plug in red and white audio out to the entertainment sys.
ur problem is easy, if you want to have sound from your audio system while watching tv programmes, you will have to have a pair of RCA (Red/White) cables to connect your TV Audio Out to an available Audio Input on your Audio system.
if you want to be able to watch DVD's with sound from your TV but not from your Audio setup, you will either need to use a HDMI cable direct from your DVD player to TV or RCA + Video cable from DVD to TV.
i know it sounds easy here when described....u try to figure out what i mean : )
