mint
How To Check That Our Water Outlet (drainage) Is Not Choked With Cement/ Sand/ Groutings?
Hmm, how to check that the contractor did not dump any sand/ cement / stuff into the 5 drainage pipes?
Dont tell me must use our hand to go in to check?
I did make a kitchen base, and when I open the drainage cover at the kitchen, I see a lot of debris, bits of cement stuck between the first layer of floor and the second layer of floor (the kitchen base).
Uuse the rubbery sensor thing attached to the end of the arm of a homo sapien...
or u use a stick to feel it's "smoothness". If stir ard.. got jerky feeling, then that suggest got remnant cement inside.
use hand.....
use hand.....
U mean it?? Or just kidding? Hand not that long leh.
Whats homo sapien ?
Edited by mint
