Hi all, I will be getting a premium flat soon. Really under a tight budget. A max of 12k for my 5room reno with the following specs.
Kitchen
- Construct kitchen cabinet base complete with side tiling.
- Construct washing machine base complete with tiles.
- Construct fridge base complete with tiles.
- Supply labour to run wiring.
- Supply & install cooker hob/hood
- Construct 15ft Top & Bottom Laminated Kitchen Cabinet c/w ABS Trimming Solid Ply Doors
- Supply & Install 10ft length high pressure resistance solid surface top, stainless steel sink, designer handles & cultery tray
Plumbing works
- Supply labour and material to run new machine inlet/outlet pipe.
- Supply labour and material to run new sink inlet/outlet pipe.
- Supply labour to install 2 sets instant heater / 1 set storage tank.
- Supply labour to install sanitary wares
Miscellaneous
- Painting of whole unit using ICI/Nippon paint c/w (4+1) colour include all bedroom
doors/door frames and all pipes.
- Re-varnish / re-paint main door.
- Epoxy paint walls of kitchen & common toilet
- Lay protection sheet for flooring.
- Chemical washing for whole unit flooring.
- Demolition master toilet floor & wall tiles.
- Dismantling of 2 toilets and kitchen sanitary wares.
- Haulage and disposal of debris.
- Supply and install 2 toilets powder coated frame bi-fold doors.
Masonary (master toilet)
- Supply and lay 250mm x 330mm heavy duty ceramic wall tile
- Supply and lay 300mm x 300mm heavy duty ceramic or homogeneous floor tiles
Is it possible or its too low a budget? :curse: Thanks so much~! :P
Edited by rav3n
Hee..my future flat will be at st 64
currently residing at st 91
Ohh is it at Blk 678??? !!
U can approach Ho Bee for quotation on ur hse reno. :bangwall:
Edited by Cantona7
Appreciate it. Thanks Cantona7 :dancingqueen:
Don mention Ho Bee got veri gd review from their customer and reliable too. !!
U can read their thread below. :bangwall:
i would think it is possible if you go to a contractor, my new house is standard 5room, i m quoted around 15-17k and mine includes flooring for whole house and some other nonsense...
gd luckz!
i am staying in old jurong west btw :yamseng:
gd luckz!
i am staying in old jurong west btw :P
hee..tks tks..will look for a contractor then. Really on a tight budget. =p :yamseng:
where is this Ho Bee at?
we got a flat at St 64 too.
got 1 quotation from Id and they are quoting us $28k.
Goodness.
many conmen + contractors faking as Interior Designers nowadays....
gd luckz!
i am staying in old jurong west btw :wub:
Wow.. tats really good price... PM me ur quotation and contractor?
Hey could i have the contacts too please?
Mine is also @ Blk 988 and looking to do my kitchen, and MBR only.
Have a relative that does woodwork but need help on other things on works like concrete base and protetive layering for the parquet flooring.
Any recommendations?
