phoenix 0 Report post Posted October 11, 2007 Hi!Does anyone know if is there any taboo for MBR door facing MBR toilet door? Is this bad fengshui?It means when I open MBR door, first thing I see directly in front is the toilet. Share this post Link to post Share on other sites
karen77sg 0 Report post Posted October 11, 2007 My mum's hse layout also the same as yrs...as in her MBR door is in line with the toilet's door...I also interested to noe.... Share this post Link to post Share on other sites
MaCe 3 Report post Posted October 12, 2007 Hi!Does anyone know if is there any taboo for MBR door facing MBR toilet door? Is this bad fengshui?It means when I open MBR door, first thing I see directly in front is the toilet.block it, partition it. or ALWAYS close the toilet door when not in use.Qi enters your house from main door, collects at the centre of your house then spread towards all areas of your house. When Qi enters mbr - it gets the squashed welcome by the toilet - your good Qi turned into Bad Qi.A good fs bedroom is actually one without a attached toilet. except for those whose bazi needs water. Share this post Link to post Share on other sites
raincole 0 Report post Posted October 12, 2007 I will not like such layout. Likely to change the toilet door location. Share this post Link to post Share on other sites
karen77sg 0 Report post Posted October 12, 2007 I will not like such layout. Likely to change the toilet door location.Bt bo pian leh...if change the door, then I tink will face the bed for my parent's case.....block it, partition it. or ALWAYS close the toilet door when not in use.Qi enters your house from main door, collects at the centre of your house then spread towards all areas of your house. When Qi enters mbr - it gets the squashed welcome by the toilet - your good Qi turned into Bad Qi.A good fs bedroom is actually one without a attached toilet. except for those whose bazi needs water.Mace, bt I tink nowadays most flats will have an attached toilet in the MBR unless those super old flats la.... Share this post Link to post Share on other sites
MaCe 3 Report post Posted October 12, 2007 Bt bo pian leh...if change the door, then I tink will face the bed for my parent's case.....Mace, bt I tink nowadays most flats will have an attached toilet in the MBR unless those super old flats la....yalor - bobian. if strike 4D, me gonna hack my 2 bedrm into a MBR and shift over. Share this post Link to post Share on other sites
karen77sg 0 Report post Posted October 12, 2007 yalor - bobian. if strike 4D, me gonna hack my 2 bedrm into a MBR and shift over.Wah....then u must buy big big...cos hack the bedrooms leh.... Share this post Link to post Share on other sites
MaCe 3 Report post Posted October 12, 2007 Wah....then u must buy big big...cos hack the bedrooms leh....hack + patch + paint = should less than 3-4k lah... Share this post Link to post Share on other sites
raincole 0 Report post Posted October 12, 2007 as long as toilet is near then ok. If not then troublesome if outside of the bedroom. Share this post Link to post Share on other sites
phoenix 0 Report post Posted October 12, 2007 block it, partition it. or ALWAYS close the toilet door when not in use.Qi enters your house from main door, collects at the centre of your house then spread towards all areas of your house. When Qi enters mbr - it gets the squashed welcome by the toilet - your good Qi turned into Bad Qi.A good fs bedroom is actually one without a attached toilet. except for those whose bazi needs water.It would be hard to block or partition it, not much space. By bazi you mean the "eight characters"? When Fengshui master see the flat, do they also see your eight characters?I will not like such layout. Likely to change the toilet door location.Yes, actually I don't really like this layout. Although I do not really know before I asked this question here, I somehow already didn't feel good when I look inside the mbr and the first thing I saw was the toilet!Come to think of it, perhaps I can change the main door location, toilet dr looks impossible to change due to the way its been allocated. But hacking doors and changing positions will damage the flooring right? Does that mean I also got to redo flooring? Flooring looks good..pity if damage and must redo. Share this post Link to post Share on other sites
raincole 0 Report post Posted October 12, 2007 Will not damage floor. Just check with your id.If already doesn't feel good, no need to talk abt fs, it already not good.Normally toilet door easier to shift than room door, less affected area but I didn't see the layout. I only know passengeway to door: front = toilet, right/left = room. Share this post Link to post Share on other sites
MaCe 3 Report post Posted October 12, 2007 It would be hard to block or partition it, not much space. By bazi you mean the "eight characters"? When Fengshui master see the flat, do they also see your eight characters?Yes, actually I don't really like this layout. Although I do not really know before I asked this question here, I somehow already didn't feel good when I look inside the mbr and the first thing I saw was the toilet!Come to think of it, perhaps I can change the main door location, toilet dr looks impossible to change due to the way its been allocated. But hacking doors and changing positions will damage the flooring right? Does that mean I also got to redo flooring? Flooring looks good..pity if damage and must redo. FSM who see the flat without seeing your BAZI - the most i am willing to pay is 50 cents as a tip, not service.if hack the door, need to patch up cos the tiles are layed up to the walls/door nia.hopefully still can find the same tiles lor. Share this post Link to post Share on other sites
phoenix 0 Report post Posted October 12, 2007 FSM who see the flat without seeing your BAZI - the most i am willing to pay is 50 cents as a tip, not service.if hack the door, need to patch up cos the tiles are layed up to the walls/door nia.hopefully still can find the same tiles lor.Hmm.. Yeah, thats my corcern ... coz this particular unit I looking at the whole flat including rooms all the same tiles. And the tiles between bedroom and living is like half-half between the doorway! Share this post Link to post Share on other sites
raincole 0 Report post Posted October 12, 2007 In my case, only the wall that divide 2 bedrooms has been hacked. the floor tiles not affect. Of course if there is wall tiles, it will be affected. Share this post Link to post Share on other sites
karen77sg 0 Report post Posted October 12, 2007 hack + patch + paint = should less than 3-4k lah...Then u must strike the top ones leh....tats y I say must strike big big ma....u still need to spare some cash to treat US leh....dun forget hor.... !! !! Share this post Link to post Share on other sites
