monksgs
Advice On My Kitchen Quotation
I just bought a new (actually 7 year old) Executive HDB in SK.
I got one quotation from ID, but have some doubt on my kitchen.
Actually it is my first time to do the innovation and I don't have much exp.
But I thought it might be a bit expensive...
here comes the detailed list:
Supply homogenous tile for kitchen/service balcony flooring ( psf $2.50 ) $425.00
Supply labour & cement to lay non-slip homogenous tile for kitchen/service balcony flooring $580.00
Application of water proofing $150.00
Construct kitchen cabinet base complete with matching side tiling $180.00
Construct washing machine base complete with matching tiling $80.00
Construct fridge base complete with matching tiling $80.00
Supply labour to run wiring & install cooker hob/hood FOC
Supply labour & materials to run washing machine inlet/outlet FOC
Supply labour & materials to run new sink inlet/outlet pipe FOC
Design custom made kitchen cabinet in laminated finish c/w ABS trimming $3,040.00
solid ply doors ( 1 year warranty ) ( Approx:32ft )
Supply stainless steel dishrack for kitchen cabinet FOC
Supply frosted glass door for kitchen cabinet FOC
Supply designer's handles & hinges for kitchen cabinet FOC
Supply & install 'bellus' brand solid surface top c/w 3"profile & backsplashc ( Approx:17ft ) $1,190.00
Supply & install 10mm casement tempered glass door for kitchen entrance $380.00
I need to purchase Cooker & hood,Sink and sink tap for my own, means another 1k around.
Then my total Kitchen will spend 7k...
Is it ordinary?
my kitchen is 4500mm*2250mm
Hope u experts can provide some advice.
many thanks and this is my first post in Renotalk.:notti:
Edited by monksgs
welcome to renotalk :dunno::)
since you are doing such a long kitchen cabinet and retiling(?) the quote looks alright to me
i didn't do retiling and my kitchen cabinet only 15ft total 8|
welcome to renotalk :sport-smiley-003::thumbs up:
i didn't do retiling and my kitchen cabinet only 15ft total :bangwall:
what is retiling? i have no idea about it...
since we will only do the floor tile for kitchen
What are the dimensions of the tiles?
Normal tiles or non-slip homogenous tiles?
And what are the range u can select from?
Please tell them to write clearly, as in point 2 it state non-slip homogenous. BUT in point 1 didnt state anything.
What grade of water proofing they are giving?
Dude, for washer and fridge base dont do first. Find the model that you want and then give the actual dimensions to ur ID/Contractor to do the base. If they do it first then u will be restricted on the washer and fridge u want to get. !!
For you inlet/outlet of washer and sink are in hot/cold or cold ONLY?
As in this quote didnt state on wherethe u are getting storage heater or? ;)
What is the brand of laminated to choose from?
This goes to ABS trimming too.
Whats the internal color of cabinet? White/color polygen or?
Supply frosted glass door for kitchen cabinet FOC (how many pieces?)
Your hob and hood need to know what brand and model you are getting. As dimension will need to give to your ID/contractor.
Hope it helps...
Is it ordinary?
Base on your mesasurements... you have a top and bottom cabinet with a ladder at the side...
Pricing seems alright to me... but i think it shouldn't be this amount
maybe you prepare say another extra 1 k as frm your quote, i think should have additional items not included.
cheers...
pm me for more info
Edited by RenoGuru
