What Type Of Chemicals used In Aircon Chemical Wash - Airconpros Aircon
Aircon Chemical wash
Aircon chemical wash is a cleaning process that involves using chemicals to deep clean and sanitize the air conditioning unit. This process is more thorough than regular cleaning and is recommended for aircon units that have not been cleaned for a long time, or have accumulated a lot of dirt and dust Aircon Servicing.
During the aircon chemical wash process, the aircon unit is first dismantled to access the internal components such as the evaporator coil, blower fan, and drainage pipes. The dismantled parts are then soaked in a cleaning solution for a period of time to dissolve any dirt and debris that may have accumulated on them.
After soaking, the parts are then scrubbed and rinsed to remove any remaining dirt or cleaning solution. The drainage pipes are Aircon installation
 also checked and cleared of any blockages to ensure proper water flow. Finally, the unit is reassembled and tested to ensure it's Aircon Chemical Overhaul working correctly.
Aircon chemical wash is essential for maintaining a clean and healthy indoor environment, as it helps to eliminate harmful microorganisms Aircon Repair such as bacteria and mold that can cause respiratory problems and allergies. It also helps to improve the aircon's performance and extend its lifespan.Aircon Steam Cleaning  It's recommended to have an aircon chemical wash performed at least once a year Aircon Gas Topup.
Supported Brands
Daikin Aircon installation
Mitsubishi Aircon Installation
Midea Aircon installation
Panasonic Aircon Installation
Chemicals use In Aircon Chemical Wash
The chemicals used in Aircon Promotion aircon chemical wash may vary depending on the specific service provider or manufacturer. However, common chemicals used in aircon chemical wash include alkaline-based solutions, acidic-based solutions, and biocides.
Daikin Aircon Servicing
Mitsubishi Aircon Servicing
Midea Aircon Servicing
Panasonic Aircon Servicing
Alkaline-based solutions are used to remove dirt, debris, and stubborn stains from the aircon unit's coils and filters. These solutions are also effective in breaking down grease and oil buildup, which can accumulate over time and decrease the aircon's efficiency.
Acidic-based solutions are used to dissolve mineral deposits such as rust and calcium buildup. These deposits can accumulate inside the aircon's cooling system, affecting its performance and increasing the risk of breakdowns. Aircon water Leaking Acidic-based solutions help to remove these deposits and improve the aircon's cooling capacity.
Aircon promotion Singapore2023
Biocides are used to eliminate harmful microorganisms such as bacteria, fungi, and mold that can grow inside the aircon unit. These microorganisms can cause respiratory problems and allergies, so it's important to eliminate them during the cleaning process.
Aircon chemical wash vs Chemical overhaul
It's important to note that aircon chemical wash should only be performed by qualified and experienced professionals to ensure that the right chemicals are used in the right amounts, and proper safety protocols are followed.
Aircon Servicing
Aircon installation
153 Yung Ho Rd,
#09-45, Singapore 610153
Aircon Service includes are:
#airconservice #airconservicesingapore #airconservicing #airconservicingsingapore #bestairconservicing #bestairconservice #airconservicecompany #airconchemicalwash #bestairconservicingcompanyinSingapore #Daikinairconservicing #mideaairconservicing #panasonicairconservicing #Mitsubishiairconservicing #aircongeneralservice #aircongastopup #airconsteamcleaning #airconchemicalwash #airconchemicaloverhaul #airconrepair #airconrepairSingapore #airconrepairservice #bestairconsingapore #airconserviceprice #airconservicepricesingapore #bestaircongeneralservice #bestairconchemicalwash #bestairconchemicaloverhaul #Airconprosairconservice #commercialairconmaintenance #residentialairconmaintenance #commercialairconmaintenance #residentialairconmaintenance #residentailairconservice #commercialairconservice #residentialairconinstallation #commercailairconinstallation #airconservicingcompany #airconpros #airconprosairconservice  #airconsteamcleaning #aircongastopup #airconleakingwater #airconwaterleakage #airconpromotion #airconpromotion2023 #airconpromotionsingapore2023 #daikinairconpromotion #mitsubishiairconpromotion #mideaairconpromotion #panasonicairconpromotion #airconspareparts #daikinairconinstallation #mitsubishiairconinstallation #mideaairconinstallation #panasonicairconinstallation #hitachiairconinstallation #greeairconinstallation #yorkairconinstallation #sharpairconinstallation #panasonicairconpromotion #Daikinaircon #Mitsubishiaircon #Mideaaircon #Panasonicaircon #airconinstallationpromotion #airconinstallationpromotion2023 #commercialairconmaintenance #residentialairconmaintenance #airconinstallationsingaporecondo #airconinstallationsingaporelanded #airconinstallationsingaporeHDB/BTO #commercialairconinstallationsingapore #airconsingapore #cheapestairconsingapore #bestairconsingapore #airconlightblinking
