genesis 0 Report post Posted September 8, 2007 Hi Warrior88,I got the following for the bedrooms :MASTER BEDROOM==============BTU = 9275 (2.71 kW)BEDROOM 2==============BTU = 8327 (2.43 kW)BEDROOM 3==============BTU = 8327 (2.43 kW)Hence I go for MSXY-GA13VA (3.5 kW) for Master Bedroom, 2 x MSXY-GA10VA (2.5 kW) for Bedroom 2 and 3.I understand Bedroom 2 & 3 might not be cooling enough but from experience, I normallyset temperature to 26C lowest since these 2 rooms are my kids' rooms and we normallydon't make it too cold. Hence, I doubt there will be cooling problem.I might be wrong here but worse case, I can still opt for 3 x MSXY-GA13VA (3.5 kW). Willtalk to the aircon seller and see what they recommend.Hi Kst,You might just want to consider using just one condenser MXY-4A28VA or MXY-4A38VA , both able to support 10+10+13+26 . Most of us don't turn on all the fan-coil , looking at your case I believe you might only use 3 fan-coils together, however, I think MXY-4A38VA meet your requirement. Share this post Link to post Share on other sites
leen 2 Report post Posted September 10, 2007 the installers must hv integrity and not cut corners when installing. to avoid future leaking problm, owner must be around when they install the piping and most imptly, be there to witness the whole process of pressurization. Share this post Link to post Share on other sites
babyQ 0 Report post Posted September 12, 2007 the installers must hv integrity and not cut corners when installing. to avoid future leaking problm, owner must be around when they install the piping and most imptly, be there to witness the whole process of pressurization.Leen, thanks for sharing all your aircon links! what must we look out for during the pressurization process? Share this post Link to post Share on other sites
leen 2 Report post Posted September 15, 2007 these are the quotes i was given for toshiba. toshiba system 3 inverter (got this combination as i need to cool a big hall and MBR) and i am installing 2 sets of system 3 (if i do decide on system 3) outdoor unit: RAS-3M23YACV - 24,000BTU/Hr x 1 unit indoor unit: a) RAS-M10NKCV - 9,000BTU/Hr x 2 unit + b) RAS-M13NKCV - 12,000BTU/Hr x 1 unit prices do not include bracket coz i hv concrete aircon ledge: a) h@ng ta - S$2,780 b) Best tech - S$2,653.60 c) mega - S$2,550.00 d) hong huat - S$3,103 e) federal - S$2,398.00 toshiba system 4 inverter (if i get this combination, i would need to get 1 more single split system coz not enough for my hm) outdoor unit: RAS-4M30YACV - 30,000 - 34,000BTU/Hr x 1 unit indoor unit: a) RAS-M10NKCV - 9,000BTU/Hr x 3 unit + b) RAS-M13NKCV - 12,000BTU/Hr x 1 unit prices do not include bracket coz i hv concrete aircon ledge: a) h@ng ta - S$3,730 b) Best tech - S$3,456.10 c) mega - S$3,400 d) hong huat - S$3,531 e) federal - S$3,400 if bracket is required, the prices are: a) h@ng ta - S$120 b) Best tech - S$150 c) mega - S$120 d) hong huat - S$100 e) federal - never state all piping and insulation base on manufacturer's spec. basically its either, armaflex, k-flex, thermaflex, totaline insulation etc. cu piping as per manufacturer's specs. piping and cabling all in pvc trunking. these are the quotes i was given for mitsubishi. mitsubishi system 3 inverter (got this combination as i need to cool a big hall and MBR) and i am installing 2 sets of system 3 (if i do decide on system 3) outdoor unit: MXY-3A28VA - 30,000BTU/Hr x 1 unit indoor unit: a) MSXY-GA10 - 9,000BTU/Hr x 2 unit + b) MSXY-GA13VA - 12,000BTU/Hr x 1 unit prices do not include bracket coz i hv concrete aircon ledge: a) h@ng ta - (mitsubishi electric)S$2,900 / (mitsubishi heavy) S$2,680 b) Best tech - S$2,653.60 c) hong huat - S$2,950 d) all best - S$2,731 e) best denki - S$3,299.00 f) double-h aircond - 3,150.00 g) golden harvest h) systematic airconditioning - S$3,100 mitsubishi system 4 inverter (if i get this combination, i would need to get 1 more single split system coz not enough for my hm) outdoor unit: MXY-4A28VA - 30,000BTU/Hr x 1 unit indoor unit: a) MSXY-GA10 - 9,000BTU/Hr x 3 unit + b) MSXY-GA13VA - 12,000BTU/Hr x 1 unit prices do not include bracket coz i hv concrete aircon ledge: a) h@ng ta - S$3,730 b) hong huat - S$3,650 if bracket is required, the prices are: a) h@ng ta - S$120 b) hong huat - S$100 c) all best - S$150 d) best denki - S$110 e) systematic airconditioning - S$100 all piping and insulation base on manufacturer's spec. basically its either, armaflex, k-flex, thermaflex, totaline insulation etc. cu piping as per manufacturer's specs. piping and cabling all in pvc trunking.Leen, thanks for sharing all your aircon links! what must we look out for during the pressurization process?hi, i got a list of checklist but its kinda long to state here. Share this post Link to post Share on other sites
babyQ 0 Report post Posted September 16, 2007 can send by pm? thanks Leen!! Share this post Link to post Share on other sites
